The Sa Wasteland
Cubes
 Share
thats what im scared of, dissappointing him.......
may i ask how you found him ruby? pm if need be
I got introduced to a cousin a never knew i had. He gave me info on my older brother who was in the forces. After a few months of gaining their trust, they gave me my brother and fathers address and I made contact.
LOL. and wow, that bodywork is beyond description :S
Bought an R32 GTR V-SPEC II shell for my drift car today. SHE RUNS!!!! heaps excited to get it out to a carpark
i'll race ya Damo, i got a two speed nitro car :) its set up for grip though :(
I got a S15 petrol car. Haven't used that thing for awhile..
got your car fixed yet mate?
ill be out cruisin sat night, missus has some girls night in charity party thingymajig.....
any one else be out?
I might be out ... but if the weather is nice, I'll be on the bike :)
Went for a ride yesterday with Kell on the back for my last day off before going back to work. Wasn't too bad for a ride.
lol, reminds me of when i was a kid, used to take the rubber off my rc car,
wet mums kitchen tiles with a mop and go sideways lol, that was before i even knew what drifting was
yeah this weekend is gonna be purrrrect for a cruise.....
bit of hills, bit of bay bit of semaphore bit of regency lol :)
33 on sunday!!
f**kin drift car is hard to handle, need more grip on the slicks.
best drift tyers to use is 2inch pvc pipe and have around 5mm sticking out from the rim's to stop damage to the rim when you hit somthing :)
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
