Off topic, but +1 to Service SA messing people around. I got told a few weeks back on the phone from them "Yep, you can get your full license. Just come in and get it". So I went down there and the girl behind the counter said "Nope, you can't get it for another 4 weeks. The person on the phone was wrong".
Stupid! 0 customer service skills.
Yep, service SA suck! Was supposed to get my P's back about a month ago, now it'll be another 5 weeks or so.. BULLS**T!!! Had one lesson on my L's the other day (as you have to these days) and the dude said i need to have a few more lessons to 'break some habbits' i have, these habbits are the ones i learnt from the first driver i had before i got my P's 2 years ago.... Its alittle hard to break them seeing i've been doing it for 2 years.. Also why the hell do they need me to do the VORT test? I've had my p's, there for i know how to park, do u-turns and all that shite, so whats the point????? It pissed me off so much when the dude told me that, swear i was gunna hit him at one point, not his fault tho, just doing his job! But seriously why do i havta do all that stuff again, i was caught speeding thru a few red light spped cameras (within 20k's) and this is what i get for it, 8 months (or more if i done pass the VORT) with no licence = bullshit! Stupid system!!!! But yeah i guess... its my own fault... :laugh: dont lose ya licence when your on your P ones.. it sucks what ya havta go thru to get them back!
My rant lol
GTR Pump will fit BUT for the cost of an old S/H pump why not buy a new 040 or 044 and fit that intank.
I fitted my 044 intank, cost $20 for the lower machined nipple a hose clamp, some suitable rubber and a little efi hose.
new pump 040 is like $220 -,-"
ebay my friend. :laugh:
some jecs pump - http://cgi.ebay.com.au/JECS-BOSCH-FUEL-PUM...1QQcmdZViewItem
and then a heap of 044's for around $200 delivered.
Theres also the Walbro which is a damn good pump for up to ~250-260rwkw.
^^ yup, had walbro in my 33, 230 odd rwkw comfortably, stock injectors where @ 100% at times
ERRRRMMM WHY IS MY LAPTOP WRITING IN CAPS WHEN CAPS LOCK IS OFF?
and lower case when caps lock is on? :laugh:
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
