new pump 040 is like $220 -,-"
stop being so cheap :cool: is that the price from Steve did you ring him ??
ebay my friend. :)
some jecs pump - http://cgi.ebay.com.au/JECS-BOSCH-FUEL-PUM...1QQcmdZViewItem
and then a heap of 044's for around $200 delivered.
Theres also the Walbro which is a damn good pump for up to ~250-260rwkw.
link >>fixored<<
went to sinergy today to get a quote to fit a new heater core was very impressed with whats in the show room saw sleds exact evil twin i almost thought he sold it that how exact it was :)
vey happy with the quote ive been given so far as opposed to somewhere else local to magil rd :laugh:
na i dont have a mate with a vx ss, i have one with a worked vx berlina though, me and him where dead equal
everytime we had a go (on private road) even though i had mass wheelspin through 1st 2nd....
cant wait to see your car on the road again man, it porn!
goes into Morpowa on thursday and should have it back in a week i hope, cant wait, havnt heard the sound of my external gate screammmmmmmmmer for soooooo long, hope to pull high 300's rwkw, then i gottr put my rotors n pads on, enjoy it for a few days then im off overseas for a month.....
anyone want to look after it for me?????????...lol
1st week-
2nd week-
3rd week-
4th week-
went to sinergy today and saw sleds exact evil twin i almost thought he sold it that how exact it was :laugh:
what were they asking for it......how many kms........was it a V-Spec......was it in good nic............more info please
while we're on the subject of fuel pumps, does anyone know if the hi capacity Nismo in-tank jobs capable of up to 400kw and would the 700cc Sards also cope?
Injector size: 700 cc/min injectors(66.7 lbs/hour)
Number of injectors: 6
BSFC: 0.65
Duty cycle: 0.85
This combination will supply fuel for 523 horsepower = 390kw
BSFC: 0.65
Duty cycle: 0.95
This combination will supply fuel for 584 horsepower = 435kw
lol dan, please take me for a drive when you get back :cool:
we have a lock up/alarmed garage if you really needed a place of storage, its been empty since last monday :laugh:
SWEET
ill let ya know
ill even leave the keys 4 ya
BSFC: 0.65
Duty cycle: 0.85
BSFC: 0.65
Duty cycle: 0.95
i had to upgrade to this size
i ordered NISMO 700cc waited 4 weeks, went to pick them up satdee opened the packet, saw the yellow and they were 555cc
they rang around for me today and no one in AUS have any so they had to order some hks 700cc and give them to me at roughly the same price for messing me around
Graig-was that a pic of your old engine bay?????????...............ahahahah
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
