for sure Dan; you ignore just about any price you'd see on the piece of paper hanging in the window of a car at a car yard.
jeez i remember the price listed in the window of my white 33 (in my avatar) when i bought it from a yard back in the day... we knocked quite a sum of that price off compared to what i paid :)
guys need ya help palease :)
oka so went to go see my car today down at premier paint n panel n its finally coming together..yay..but a lil problem has occured..they have gotten my car to start and god does it sound good to finally here it again lol but now my hicas light is on and the steering is heavy as...ive had the hicas light on before but the steering wasnt affected..all i did was change the power steering fluid and it went away.
the guy said that had to disconnect some hoses around the power steering pump to do some work so im hoping that it just needs a top up of some fluid
would i be right??? or is it something else??
there hoping to have my car finished by this friday....cant wait :)
ur help will be appreciated.thanks
you will prob find that due to the car sitting around for so long, all the fluid has drained from the lines, and dried up.
give it another change, and see how you go :)
good to hear its nearly done...
This might not be the issue, but my Hicas light was on a while back and the steering was really heavy. It turned out to be a loose battery terminal (no bullshit). New terminal and the issue went away.
Check that, but more than likely it won't be that.
But check the power steering fluid and the hose connections.
Last night after work i decided to go to town on my dump pipes with a die grinder. Where the 2 pipes join together i ground out the hole to perfectly match the shape of the smaller pipe, spent about 1 hour on them as they are stainless so had to try and keep the metal cool. It should help to improve exhaust flow a fair bit :wacko:
hmm, how are b pillars stuck on? (The black plastic that is between the front and rear side windows) just glue?
On 33's theres a couple of lugs behind there, just pull the bottom out gently until it unclips (you may need a flathead) then lift it upwards. I've never tried doing it on a 34 so it might be different.
went and had my car remapped at turbo tune today and i gained 34 rwkw out of it
first run pulled 88.1 rwkw with a blocked fuel filter and fooked fuel pump..so replaced both of them and it pulled 111.2 rwkw
then after the remap it pulled 122.2rwkw..
im pretty happy with it considering the only mods are HD clutch, 2.5" full exhaust system with race cat and K&N panel filter
    • Since this is the page where i found myself while searching for wheel fitment, i will add the ones im looking to replace too. Fenders arent rolled, so in big bumps they touch the tire (tires could be narrower). no any adjustable arms, so the camper is what it is (dont know). Wheels: 5ZIGEN Fireball Front: 18x9.5 ET12 - 245/40 Rear: 18x10.5 ET25 - 285/35
    • That’s a beautiful setup Tao, Have u done any development with the new Turbosmart 40mm electronic straight gate, especially in this G30 configuration?
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
