The Sa Wasteland
Cubes
 Share
:D yeah good luck with that.
Go the 31 if you just wanna go out and thrash something. Take your 34 out there if you want to learn more about the car/driving in general. Once you get over the fear of bending a good car its much more fun.
AE86's START at 9k imported...
And that's with only 10% covered in rust!
dont know where you 2 guys are looking for AE86's
http://www.tradecarview.com/used_car/japan...trueno/1455433/
http://www.tradecarview.com/used_car/japan...trueno/1381123/
http://www.japaneseusedcars.com/auction/tu...o-28691719.html
http://www.tradecarview.com/used_car/japan...trueno/1111544/
http://www.tradecarview.com/used_car/japan...+levin/1515519/
and there not the cheapest spec ones
Hmmmm
need money :P
50mm wide body rears for a 32 4dr ;)
Would look fking ace with some GTR front guards & bar.
find those for a R33 4 door and i will love you for ever
I got fruchocs and coke! Close enough.
So im confused but agree with Adrian KEEP IT OFF THE DAMN FORUMS!
i used to work a robern menz :down: mmmm chocolate coated orange bits
Boring.....
Bitching on the net is gay and having to read through it to find the good things to read is even more homo. Is SAU full of 16 year olds now or what?
Because I'm bord, I'm going to borr you all with me. Here's some dodgy pictures I took not long ago. It's only a shitty old camera and ive never done anything fancy with one before so cut me some slack :D
all depends on the yen on the day general rule of thumb
car cost Yen FOB = at the docks
$1100 shipping+10%gst+10%customs+$600 Quarantine & other government charges+ $3000 compliance + broker fees
OH YOUR SO BORING KYE...
.no really you are JK lol good job man
PLEASE!!! i would kick your ass at halo and i dont even touch that gay-box 360 anymore :D
dont be mad dan, one day ill let you back around to play some more ps3 :down: .................................one day
cheers steve ;) you funny bugger
Edited by Import S13
Those pics r sex. Love the paint job.... wish I had one as good ;P
-D
thats gaylo 3 to you
and way to make me realise the tool i am having to nag the rich kid to play the latest and greatest games :D can i come over mum says its ok
im still playing galaga here, apparently games have moved into a get this "3rd dimension"
forgot to put ur window up ;) n get a night kids sticker
Edited by Inline 6
 Share
    • After I unplug maf car dies, won’t start. Same with iacv valve - two connectors mounted behind manifold
    • here’s link to photos bcs can’t add it here blue spots - I can install recirc valve hose there and in general everything air intake related so you can spot of anything wrong here
    • Sorry for late answer but here’s my spec: Series 1 1994 r33 gts25t AT converted to MT using r32 rb20det gearbox. Custom self made clutch pedal os giken twin plate clutch two pins connected to let engine start speedsensor from AT connected to wire harness but didn’t fit to gearbox So it’s somewhere inside in the car so I can add km to tachometer after I measure distance with gps. Don’t want to pay 150€ for sensor if I probably will change gearbox with adapter to bmw one. Car barely runs and winter is coming so no point right now  engine after rebuild Stock automatic ecu and at tachometer Aftermarket oil cooler with separate sensor so oem oil pressure is unplugged  koyo 53mil radiator  Mods which may cause the issue: 600x300x76 front mount intercooler Cone air filter blitz Removed recirculating valve Slighty bigger maxspeedingrods turbo adjustable manual boost controller (didn’t set it but last time I checked on aftermarket gauge it was 0.4bar, asaik oem is different unit 7(unit) don’t want to rev it too high bcs it made max 70km after rebuild Fuel pressure regulator set to idk 30-32psi at iddle dw300 fuel pump stock injectors check valve right in front of fuel rail i thinking sth wrong with afr it getting too much fuel and too less air or it needs that recirc valve? on warm engine it took 5-10 seconds to start it. After I put way bigger battery, battery terminals and new ecu coolant temp sensor problem is gone my old turbo spill 150ml oil into intake so cleaned it.    I checked for error codes and it given me 55 - all good. I bought consult so will plug in soon to check if it give me better feedback. Also I will install oem recirc valve tomorrow. Small hose going to manifold but where should go 30mm pipe from this valve? I’m front of turbo inlet, after maf/ right after turbo outlet / or it doesn’t matter? actaully can install it in these two spots (blue circles)
    • I think throwing the hydraulic power steering system into the trash and converting to electric power steering, e.g. Astra PS pump would solve many issues.
