And to think ive been a sucker this whole time...
yeah man. grimace from mcdonalds is purple, yet he set the land speed record in '85. True indeed that he only did it cause there was a big mac at the end but it beats letting the hamburgler get it...
-D
What is victory? Is it to defeat your enemy on the field of battle? Is it to simply repulse his armies and slay his misguided warriors? No, this is only the beginning! True victory is to crush your foes utterly, to shatter his armoured legions and run down his fleeing troops as they scatter. Pursue them to their lairs and burn them out. Burst into his unholy temples, smash down his icons and topple his foul idols. Burn his heretical works and leave no stone upon stone. Slaughter his followers, their families and their livestock lest any of their taint remain. And when that is done, put the ruins to the torch.
Any that have dealt with them or given then succour must be obliterated, for memory is insidious and though you have crushed their will and their bodies they may yet return. Send warrior scribes to excise the records of their name, expunge their deeds from the annals of history and remove even the memory of your foe’s existence. Only then have you truly won.
That is the meaning of victory.
All comes down to 'needs' and 'wants'.
I want an RB26 powered Stagea right now ... but I need to do the house extensions on my place :banana:
lol Roo, I really want & need one of these!!!
Very Special
Oh and Pete. If your selling your rims I would go for TE37s! Can vouch for how light they are as I have a pair of them in 18"
I'd get them in Bronze or black on the silver that'd look awesome. Go high offset over width though, really deep spoked 37's look the best.
Jarrad, I can only get through 2 or 3 words at a time of your post before running to the bathroom to throw up everytime........not even the freakiest ride at Dreamworld would make me that dizzy, lol.
Haha, but thanks anyway, I know what you mean about TE37's, they do look tuff.
mate, dont even try...they are very confusing and dangerous to your car if you dont know what your doing and without a dyno. Take it to my mate at Aussie dyno and well set it up..I've set up a couple and they are fairly hard to get spot on...It's not just a matter of punchin in 10psi and hoping for the best.
On that note, has anyone had any success with these, it drives me nuts trying to set it up.
HKS EVC 5
whoo hooo just sold my boat big choice now spend the lot on my skyline or invest it ????????????........20 odd grand would buy some nice mods lol
Buy shares whilst they are down, make a killing in 12-18 months. Some of the share prices at the moment are ridiculous, there is a killing to be made now for people who have the cash and weren't hit by the drop.
^^^^ agreed put it into shares for 13- 18 months... your bound to gain a fair chunk of money.... so far ive lost enought to buy a 34 gtr, i invested just before the crash too so i certainly am kicking myself!
on another note had thursday off... put back on carbon air box and took off cam gear cover... also adjusted and tinkered with a few things here and there... very happy ith the looks now just need a carbon coil cover.
Time for a bash through the hills then. :)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
