haha, at first i thought ben was doin it on purpose, then he pulled over and i was like
oh ohhhhhh........ thats not good.
but thankfully it wasnt anthying bad!
spewin we missed the tunnels though!
Craig, continuing from the accident thread.
I get looks and sAfrican Americans all the time man. Every from my own family, especially my dad.
One night at tea we were sitting down eating and I was telling him something about my car. He got up and walked into the kitchen came back with the bin and put it on the table then said to me "Here, put your money in here" and walked out.
yeah, some people just dont understand the passion mate.....
my GFs mum was the same, but i got her good,
she smokes and plays pokies, atleast i had something to show for my money!
I WIN OLD LADY!
you work hard for your money, do what you wish with it imo!
cant you just weld it up Cubes, or is it totally stuffed??
I could try all though the heat may? damage the actuator, nothing to loose though I guess lol.
I need to replace the actuator any way as when tuned the most boost it would hold was 17psi and now with similar ambient temps its down to 16.6psi.
Wound a heap of preload on to it ~10-15mm but made no difference. The gate is being blown open which is partially due to the dump design but its better than having boost creep as its easily fixed. :)
if you get water onto it straight away it should stop the heat travelling down the metal, if you can get it off i could have a go at welding for you as i work at Ascott welding :P
Edited by DSTROY
Thanks for the offer but its all done. I only have an arc welder but its fine for little jobs like this. The weld appears to be plenty strong.
The old man has a mig but be buggered if i can get the travel speed + wire speed + amps + gas all sorted out to get a decent weld. :P
Now to find the end bit that screws on and attaches to the wastegate flapper arm. Hopefully I didn't leave it in the engine bay last night when it was dark while I was cursing. :S
FREE STUFF!!!
-bleed valve
-rb25 top radiator hose
-R33 door sills
-rb25 turbo heat shield
-mushroom pod filter (not the best for the bigger power cars (sufficated my 33 after 3000 rpm)
come get it if ya want anything.i dont need it!
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
    • I'm 22 years younger than you mark, and I'm operating in the exact same way! Ha ha ha
    • All clamps are oem    one question is , what is the bit at the top on high pressure pipe where it connectes to intake manifold and other side goes toward the engine( see item in red circle in diabram attached)   ? Seen some people stating that should be removed on boosted application and skyline is boosted from manufacture so little puzzled. Mine is around 23pwi (700 hpish)   also some state it could be the bonjo bolt crash washer so bought two washers
    • what do you mean dead platform? People buy older, out dated and less power cars on "Dead platforms" for over $65k all the time.
    • That is really nice! Very nice finish when you have an oven to do the crinkling nice and evenly!
