I got a good mate of mine that could help you out Pete, i'll give him a call tomorrow.
yes please Chad :P
Pete, told you I can get you gyprock if you like at a nice cheap price. If you're interested, SMS me and I'll get in touch with my mate :)
thanks Luke, I did remember you.
I may be able to get the material cheap through a builder mate of mine (possibly uses CSR) but I just need a hand to do the work.....happy to pay.
Speakin of jobs, I love mine! Average around $800-$1000 weekly, freebies.. bonuses, commision, and relaxed as place to work!
Oh and guy, we have a plumber we recommend, can sms you his number tommorow if u want? Best mates with one of the workers, so does a good job if you saw we sent you!
otherwise you get a subpar job and you have to keep calling him out :);)
i also have a dyno printout thats shows i have 274rwkw and one that says 229rwkw, with no changes to the car at all just different dyno's, but my PFC says they are at 100%, so i have no idea what power reading to believe. Cant wait till saturday so i can see what the boostworks dyno says :P
yeah will be good to run against more of your peers, i was always dubious of your claimed power reading when me and Jenkies drove next to you before he had all that work done
yeah will be interesting.. What boost are u running again?
Usually it takes a good 15psi to crack 240rwkw on stock turbo's on Boostworks dyno.
260rwkw @ 15psi with cams.
Shauns dyno used to read around 10-15rwkw lower than mainlines depending on who straps it down. I'll be there on Sat but unfortunately not running. Too busy with work and cant get down to MTQ to pick up bits to fix the car. :(
ah spewn still dont get to see the sleeper on the dyno :D
***keeps typing fingers away from the$100 formal drive thingy, that thread is gonna get nasty lol***
i lol'd
Guy, what do you need done? I know a plumber (name is Adolf, lol) and he may be able to help. Did the plumbing on my bosses house down in Normanville if you are interested
I am building my house at Inglewood, but its been held up by 2 yrs thanks to council. The budget is very stretched (thanks to an additional yrs mortgage repayments and ever increasing prices) so I am looking for some traidies that will do cash jobs (with me doing much of the grunt work if possible). I have the underfloor plumbing done but will need to do hot and cold water plumbing next (lay 20mm Rehau hot and cold pipe, fit all noggins etc)
I have nearly got my builders licence (Site Supervisor and Contractors licence) and have had experience as a labourer for many trades, so I am attempting as much as possible myself and leaving the jobs I know I cant do to the professionals.
Can also pay in meals and booze LOL
Edited by 4door_Sleeper
lol, I've seen this come up a couple of times now whilst trolling through the main For Sale thread.
Whatever you do, never ever buy any kind of block that has been bored unless it comes with the pistons that it was bored to suit.
So many blocks for sale that have been "freshly bored" but don't come with pistons..........pistons can vary by up to .005" or more between manufacturers and even more between cast & forgies.
If you buy a block that's been bored for cast pistons and you use forged pistons (unless the forgies have clearance already built into them) you're asking for nightmares.
Forgies require more clearance than cast pistons due to heat growth.
Not only that.........you don't know who did the final hone, what stone or paper they used, and what degree cross hatch was used.
Buy pistons first, give them to the guy on the boring barr and bore to suit them with a torque plate!!
right on!
more people getting packages....and just got an email from someone from GMH saying in the first 1/4 of next year their shutting down for 22 working days!! YIKES!!!!
Penny its probably split and i'd guess that its a press in/press out job?
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
