Well just got back from a quick test run...
Took me a couple hours to fit the climate control's hot/cold door actuator and the rest of the interior I had to take out to get to it... mate of my soldered the dry joints last night...
and IT WORKS! Holy smeg! I haven't had a working climate control since I bought the car and I >finally< have airconditioning at my whim!
RAWR!!!
feel the power! revel in its awesomeness!
Thanks to madaz for showing me the tutorial link, I probably would have missed it otherwise. I owes you a brewski mon!
*sings a song about summer and climate controls while dancing a jig and drinking a beer*
-D
hey guys,
got my car today.. and it dies whenever i clutch in when it warms up..
its got apexi turbo, stock ecu, stock afm, bov blocked off, 3inch turbo back.
any ideas on wat would be causing it?
^ could start with like a process of elimination of things Adrian.
first thing that springs to my mind is get someone to make it stall the way it usually does while you watch from outside. If there's any black smoke coming from the exhaust it's simply too rich at idle/off throttle. If not, you've eliminated overfuelling to be the cause at least :D
Mine did the same Adrian when I used to clutch down to change into 2nd. Sif you never msg'd me to meet up somewhere so I can see the car.
sorry man i JUST finished work! catch up tomorrow night?
Hey was thinking bout going into town friday night or sat night as well!! Gouger street you say eh, might see if wifey's keen n head in!
im interested if others are, last time i went they had those cut out new lancers with forza 2 hooked up to the steering wheel n pedals n stuff schooled all the people around :D for free i might add.
plus ill be done with uni for the year and in need of alcohol :P
RAWR!!!
-D
thats awsome! im yet to own a car with air con :P
i'll let you fix mine up too :D
hey guys,
try unblocking your bov and run the standard one and see how you go?
Well, while we're being stupid, I'll run a pipe off the back of the turbo into the cabin, then I'll be too deaf to hear them complain :D
and be killed by the noxious fumes.
... win win really. :P
... win win really. :wub:
Yeah well I get that already when I only open the front windows, sucks in a lovely aroma of unburnt fuel (see my profile :laugh:)
But yeah I reckon thats a goer, I'll get on it tomorrow :D:P
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
