Hi Roo...
teaspoon full of cement babe.. LOL!
I would ... if I had a lunch break! :(
Almost finished a few edits on this drawing. Finishing up in about half hour and just going home to knuckle down some CAD drawings for my project ... and complete the wall and floor framing for our house (hope to have the plans for the extension ready for lodgement with Council this week). Also gotta proof read Tracy's assignments.
... don't think I'll be in bed until midnight tonite :ermm:
Right ... this is one problem solved :ermm:
Figured this feature was on SAU somewhere. He's just persistently annoying and I've decided he has nothing intelligent to say. Ahhhh ... bliss
anyone knows whats happend to that Sly GTR today? apparently had a mishap on main north rd near the ford dealership. Hope its nothing major.
Edit, Also what RB30 bottom end do i need? Matt told me but i kinda of forgot.
Edited by Luke_ENR34
Yeah Luke, apparently got sideswiped... didn't look too good from what I was told and I only saw it seconds before it happened!
As for the RB30 bottom end, I beleive it's out of an Series 2 VL... atleast that's what I remember from my research
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
    • Plug and play. Need a tune. It's a PowerFC, same as any other PFC, just not needing an AFM.
    • Genuine GTR seat? There are none you would actually want for <$3k a pair.
