is one better than the other?
and has anyone done a 26/30 with a Getrag hanging off it?
Hey Luke, get a price for 2 bud ;)
think that the S2 motor is the same as the 31 block, im sure ryan will know the exact bits tho
The series 1 VL block doesn't have any oil, coolant ports on the side of the block, nor a return point. They were all blank when they were casted. The series 2 and the R31 RB30 blocks are identical in the fact they have the Plugs in all the feed points. Km's wouldn't phase me either on these blocks as they are brilliant castings. Pulled the head off a clapped out rb30 with 440,000km on it only to find it still had original hone marks on the bores. You wouldn't go to the trouble of twincaming an rb30 without a freshen up anyway.
Edited by Ryanrb25
Wow! A lot happened on the SAU-SA soap opera today. I knew I should have set my video before going to indoor soccer.
So let me get this straight:
Cruises have finished? :O
SAU gangs have formed? ;)
Police are to be notified everytime we start our cars? :)
And everybody here has sand in their...body? :P
You all make me LOL! Thankyou. Peace.
picked up the 200 yesterday. epic fun. :P
anyone knows whats happend to that Sly GTR today? apparently had a mishap on main north rd near the ford dealership. Hope its nothing major.
yeah, saw that, saw him cruising up north east when i was headin in to pick up the 200, and then parked up and looking somewhat worse for wear not too long later near the ford dealership. mad me sad. :)
shotgun his front bar. but yeah sucks to hear, hope it isnt to bad.
wasnt much left of his front bar. took a nice hit to the front right corner.
Just took the 31 down to the boys at Aussie Dyno (& Mufflers) to get a new cannon coz i snapped mine off lol. Very helpful and polite guys! And now that im on uni holidays, time for all the other pointless crap to go in that i had just lying around ;)
RIP ... Wendy Van Gasteren
http://www.news.com.au/adelaidenow/story/0...008-910,00.html
Killed 2 years ago today at O'Halloran Hill by motorcycle colliding with a pedestrian and then traffic behind not seeing her.
Was one of the best friends, neighbour, riding buddy you could ask for.
A tragic loss to the motorcycling community in Adelaide, who co-coordinated with me a few awareness programs. Not forgotten.
Ride safe, drive safe.
Edited by RubyRS4
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
