Plug in 66% as you had previously or slightly less. Might be worth going a little leaner with 60%.
When cranking go full throttle.
It probably won't start because the plugs are wet fouled then its just a big vicious circle. :S
i tried that the other day to no avail.
Adrian, we need to pull the plugs out,start again..I'll get it going after the job interview.
Edited by Ryanrb25
well.........
the car seems to be running on 4cyl with the new injectors in.. so out the injectors come and off for a flow test... hope two arent f**ked...
oh well we will wait and c how it goes... its all a learning curve!
Checked the injectors are receiving power with a multimeter?
The injectors always receive volts so simply turn the ignition to the on position and check with a multimeter.
The ecu earths the injectors to trigger them so obviously shove the neg of the multimeter on the chassis/battery.
Runs on 4.. Are you sure the plugs just arn't fouled.. Thats what a mate of mines did for a while we warmed it up, raised rev's and she cleared up. :huh:
Not in the mood.. Go and have a bat. lol.
Run it for a good 5mins or so with rev's slightly up.
Make sure the injector correct is set right so go with 'slightly' lean at 65%
.... It could be running for the weekend ...
Another way to check the injectors are firing and when they 'should' be firing is to pull the cas out; ignition to the on position and then spin the cas clockwise slowly when looking at the shaft from behind. You'll hear the injectors click click click. Make sure they follow the firing order. :unsure:
[Vent]
Put turbos back on, sell car?
Pay for removal/reinstallation and just take it in the nuts?
Sell engine, buy R34N1 engine + turbos and apply for an engine conversion?
In SA, that actually seems like a good idea....ARGHHH.
[/vent]
yeh ive done that before but not with the new injectors.. ill give that a crack later..
if there not firing wats the go? there rooted?
[Vent]
[/vent]
how much for the n1's? my car needs a chrissy present
If there not firing its multimeter time to see if the problem is with the loom or the injector.
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
    • If you do make them, im sure you would have a number of buyers.. Every GTR I've been in have rattly door windows
