If your after cleaning and flow testing go to Petro-Ject in Stepney, they do a lot of the work for workshop in the state and they also sell the cleaning and testing machines and are dealers for Bosch.
PETRO-JECT SOUTH AUSTRALIA
Unit 5
28-32 Stepney Street
Stepney
PH: (08) 8132 1622 (Gerry)
Unit 5
Stepney
I have used and recomend these guys myself
Not sure they are open on a Saturday but its worth a try.
wats a flow test go for these days?
I had them take the injectors out of my fule rail (they were very tight)
Flow test, spray patern check and reports
New end caps (easily damaged in removing tight injectors - use vasaline when replacing)
all up $200
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
