^chill out mitch, They are your neighbours...go in your room and play with your lego or something.
ryan your correct, its has a t3/t4 fange. not sure what 1.06 is can you fill me in on it.
cheers... michael
1.06 is the size of the rear housing on that specific turbo. A 1.06 rear on an rb25 will see boost far too late in the rev range. Your best option is to swap it for a .82 with an internal gate or .63 with an external gate to spool the turbo a bit earlier making use of the turbo on an upopened motor. By all means try it and it will still go fairly well, but you will pull it off later when you realise it's too laggy. A swap over rear housing from MTQ will set you back about 500-600 bucks.. Save yourself the pain and do it before you put it on.
Edited by Ryanrb25
just saw australia in gold class....
AWSOME movie!!! woot
I dont care what anyone says. You name a movie after a country and expect it to have any long lasting social value?
f**k no.
Luhrmann is an artiste. He's really good at creating unique pieces but cmon, last few movies he's made havent exactly been classified as realist.
I haven't seen this. I will though. And I hope my bias against this movie doesnt make me hate it unnecessarily. But whenever you try to summarize a country up in a 2 hour hollywood format movie, made for those people with short attention spans (and even less education about the world), then its pointless. So too is trying to find our national identity in a period drama. No offence to Campion, Weir, et al, but modern australia doesn't need to be reminded of colonial past; indeed its something that the nation needs to move away from, to truly embrace the potential of multiculturalism.
Anyhow f**kit. I've lost half of you already. Go drink more beer ffs, I know I will.
end rant.
-D
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
