No you guys dont understand....I NEED a GTR. It's why i was born.
Oh, you mean like Ash was born to catch Pokemon, and you were born to drive a 33 GTR? i see now! you get dibs on the first 33gtr that comes up, shotgun second.
With fuel being half reasonable I'm seriously considering stepping back in to good ol V8.
This time around with a slight difference - a couple of turbo's hanging off it. ;)
Only issue is it means I'll have to put up with a rattling dash and poor build quality with a car thats done low km's. :S
hahahahaha
a mate of mine built a twin turbo VZ SS ute (outahnd are the plates). it pulls like all hell in every gear, but son of rajab is it tacky
I bought a VS V8 5speed back in 99' that was on the road for 1 year only for the dash to rattle etc.. Drove me mad as it was a basically a bran new car.
Ryan both of those cars sitting next to each other looked like they rolled off the factory floor. Unbelievable condition.
finally i think the airport in Bangkok will finally open tommorrow so i can f**kEN come home if not i gotter travel a further 3 hours at 12 am to a military air base to catch a flight at 8am.............i just wanna come home and pick up my car and so Ryan can put my new bakes on........all ive been doin is shopping and wasting money coz im that bored
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
