check all your connections to the afm
check to see if nothing is unpluged mate
kool will do that cheers
also forgot to mention that when driving the hicas light will randomly flick on then straight off n the steering goes funny for that split second.
Another thing too is that when driving under light throtle (under 3000rpm) my car starts to like jerk.
This all happened after that guy started to take my headlight out but didnt n then put it all back together while he worked on it out side while it was lightly raining...and its fkn anoyying the shit out of me :P
also got hungry's half price when i woked at city cross (had nothing to do with the ''realations'' i had with the manager) :yes:
hehe, yeah, i forget the store managers name now.... the big lady....
apparently this certain ''friend'' of mine had a baby....
Stop humping the boss! :D
I am up for that
i need my plugs changed but dont know how to regap those f**kers
what the???? changing and gapping plugs is like the easiest thing to do on a motor, cant beleive everyone on here whinges like its so hard :yes:
whats the point in owning a modded car, or any car at all for that fact, and want to be called an enthusiast when you have no idea or no will to get your hands dirty and learn...
Fark me, workshops must make a killing out of some of you guys
end rant
you can't exepct everyone to know everything about their cars, thats why there are workshops around, professionals who do it every day. I bought my car knowing f**k all about skylines, but i know a hell of alot more know, and just because i need or ask for help for some stuff doesnt mean im not an enthusiast.
end rant
I know how to change spark plugs and have done it on the 33 but have idea how to gap - I've only heard of people talking about it but havent done it myself because it hasnt been necessary for me yet - we all got to start somewhere to gain the knowledge!
Instead of ranting I'm sure you can explain how to gap them yeah? :D When the time comes I'd just SAU-search for google it anyways.
I agree. Gapping plugs is the easiest job on earth.
However some people are not comfortable with doing it themselves until they've seen it done. Then they'll be kicking themselves because its so easy.
You simply need feeler gauges. Head to Vilis tonite with tool kit. I'll bring my feeler gauges and show you how to do it. :yes:
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
