Well lucky me i had my car egged last nite and didnt realise until this afternoon. So know not only have a got PAINT CHIPS but also marks were the egg yoke hase been sitting. I HATE WANKERS who F**K with other ppls car coz there better.
END RANT
END RANT
unlucky dude
i had some pricks egg my commodore once , caught em and taught em a lesson .
ended up being wankers that used to try give me shit at school
its such a low thing to do.
had some exhausts quoted today, 3" mandrel bent pipe, centre muffler, resi, and drift pipes, et wanted $880, aaa only wanted $550, for the same thing...
my car will be at ET tomorrow getting a 3 1/4" straight through catback system which i have asked them to make "AS QUIET AS POSSIBLE BUT WITH MAXIUM FLOW" was quoted $750 in mild steel
does anyone no where i can get a set of R33 GTR rims/tyres from or even just rims???
Japanese import spares wanted $1,200 with nearly bald tyres $1,500 with average tyres
Japanese motorsports wanted $1,500 with good tyres and $1,300 for just the rims
Wheel Worx dont have any but said they usually sell for around $1,000 or under
does anyone no how much they should be selling for???
i need ASAP
i need ASAP
Those prices sound about right. 32 gtr rims go for about 800-900 and 34 gtr rims go for about 2k.
how does she go dan?
its still at MORPOWA
they found that the exhaust was restricting flow because of the mufflers (which i had changed to make it quiet) was making a strange noise from them while on the dyno, had a look and found they wer'nt straight thru mufflers and prob packed full of wateva is in em to make them quiter
also Simon thinks going from 19" rims to 16" rims has made a difference on the dyno something to do with the circumference of the wheel or sumthing which affects the load on the dyno so it gives a lower reading than what its capable of
so its off to ET tomorrow on a flatbed for new exhaust and hopefully i can find a set of r33 gtr rims
my car gets tune tomorrow....
anyone know how to wire in wipers??
mine dont work... will give favours hehe...
just need them done before the weekend!
working wipers should give u an extra 40rwkw i think Adrian........lol
goodluck tomorrow man hope you a get a good reading, what rwkw are you aiming for???
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
