can someone plz tell a non mechanic what the dial on the right is? seems to be oil pressure yeah? the 1 that says 1 bar but has a oil pic next to the boost gauge.
boss just picked up, i drove it while still fresh out the packet at around the 60k mark on its clock :banana:
in the process of practicing euro accents to get the stereo to work off voice activation
Edited by Inline 6
finally getting around to doin fun shit to my ipod touch. getting some apps, using works download, and then downloading iTunes 8.1 ish and the 2.1 version firmware for the ipod, also using work download :P
Hi guy's I needs some help.. I may be getting a trust td05-16g turbine kit complete with manifolds, waste gate and front pipe... My question is this anyone here know of anyone or has used them themselves?? as i want to see when the come on boost etc.
I have searched the net and cant find s__t... Any advised would be great
Cheers
so, thanks to our friendly neighbourhood nightcrawler, i now has wheels. awesomes.
and i shall be heading to aaa to get an exhaust sorted soon. double awesomes.
and i should be getting my coilovers by mid jan. triple awesomes.
and, ajd is coming up soon. epic awesomes.
Edited by scandyflick
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
