can someone plz tell a non mechanic what the dial on the right is? seems to be oil pressure yeah? the 1 that says 1 bar but has a oil pic next to the boost gauge.
boss just picked up, i drove it while still fresh out the packet at around the 60k mark on its clock :banana:
in the process of practicing euro accents to get the stereo to work off voice activation
Edited by Inline 6
finally getting around to doin fun shit to my ipod touch. getting some apps, using works download, and then downloading iTunes 8.1 ish and the 2.1 version firmware for the ipod, also using work download :P
Hi guy's I needs some help.. I may be getting a trust td05-16g turbine kit complete with manifolds, waste gate and front pipe... My question is this anyone here know of anyone or has used them themselves?? as i want to see when the come on boost etc.
I have searched the net and cant find s__t... Any advised would be great
Cheers
so, thanks to our friendly neighbourhood nightcrawler, i now has wheels. awesomes.
and i shall be heading to aaa to get an exhaust sorted soon. double awesomes.
and i should be getting my coilovers by mid jan. triple awesomes.
and, ajd is coming up soon. epic awesomes.
Edited by scandyflick
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
