FAIL for the cop who tried to pull me over last night :P
Took Tracy out for a 'date' on the Brutale and we had no probs all night. 2 streets from home I need to make a left at roundabout and then right at roundabout and then pull up my drive halfway down the road. As I'm approaching the first aroundabout to make a left turn, I see a cop car 150m ahead past the roundabout sitting at a side street. He sees my single headlight ("you beauty, a motorcycle to pull over") and turns towards me instead of away from me like he had indicated. I do my left turn, and just before the right turn at the next roundabout I check my mirrors and see him turning to follow me, and he's hiking it. I do the right turn and give it a squirt to my drive way and pull up. Security light comes on so I'm visible for all to see. The cop car slooooowly drive past my place and he stops for a moment as I'm getting my helmet and gloves off. I'm telling Tracy "wait for it, Mr Quota will do anything for a free feed".
Cop drives of real slow and I wave to him and yell "maybe next time". Then he stops near the end of my street and he's looking back at me an awful long time. Then he drives off. Fail. :rofl:
What annoyed me was: all he saw was a single headlight coming down the road, yet decided he was going to pull me over. Now he would have been hiking it to catch me in that amount of time. 11pm speeding around a suburban area for the chance of a free feed. I'd done nothing wrong, but he would have hauled me up to fill his quota. Good luck with that champ.
Lol Ruby!
Sounds like the time I was driving down to Boostworx. I was going along Goodwood Road when a cop on a bike pulled up behind me out of no where. He then basically tailgated me down Goodwood road, then turned off with me down Boothby street. I did everything right (indicated, etc). Anyway, he's still right up my ass, so instead of pulling over to park out the front of Boostworx to drop off the car, I just drove into the workshop lol and parked it inside. The cop on the bike then drove up the driveway a little bit, but then stopped and turned his bike around when Shaun and Troy walked outside lol. Then the cop just drove off slowly, just looking at us.
Then, once the cop left, I just reversed the car and parked it in the street.
Daniel 1, Cop 0.
lol, its funny coz its pedobear. i dont agree with what he stands for however.
your a foolish man if you think you can like something but not endorse what it stands for
i bought ben the new need for speed undercover for christmas... gave it to him last night... i think iv'e just lost my husband for a solid 6 weeks! :domokun:
hahaha it wont last long
wow sau just changed, always shows post #1 of the thread up the top! good idea imo.
nope just changed for you
you cant even compare the 2 behavior patterns if the joker was a real life person doing what he did you wouldn't think the same
give a thought for all the parents out on SAU 1 of a parents worst nightmares would be there child being taken by such a person and never to be found again
i had a cousin taken my Bevan Spencer von Einem many years ago and it ruined that side of the family for many years
sometimes you guys need to think before you all act this isn't just aimed at Damo
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
