The Sa Wasteland
Cubes
 Share
how much? will they fit in the single DIN position under my stereo???
are they out of a r33?
They'd fit in a din sized slot easily, the main thing you have to find out is if the cables are there for them to plug in - integrated GTR gauges get their readings from the ECU, not an independant sensor. My GTR's centre gauges have two plastic plugs that clip in to the back, not sure if those plugs are there on 33's and 34's or non GTR's
-D
need $100ono to go towards new tyres on the front of my car as they are forked.
yes its single din , i had em in my skyline just to fill the gap between my air con and fold out screen
yes they are from an R33
as Dohmar said above^^^^
do u have the plugs for them???
i'm not gonr hook them up 2 my ecu, i just need the plug to have the pos/neg/illumination wires, thats all ill hook up
by the looks of it, in a GTR it must of been where the climate control was coz the right side has no corner so if i fit it under my stereo there will be a slight gap
nah dont have any plugs , just the unit its self
here is my stealth ute shes a monster now with the black sunnies and truck pipes, wonder how long till the cops pull me over bout it. :)
keep a look out for this at glandambo 4x4 event if anyone here goes to it you might see me there this year. im gunna jump the table top and land in the mudpit, hopefully land on all fours.
on another note is it illegal to have your cam gear cover off as i want to get some purdy red cam gears.
have u got a tray on the back of that? can guarantee with no tray or protection over the rear wheels you'll get looked at, but otherwise id say it'll be stealthy :)
Pacific Islander, it enjoys playing rugby. Not sure what it is, just advertised as a fighting fish.
looks like this, but marrone all over:
prepare to be dazzled...
ours sat there and did f**k all for 2 years then it died...all they do is sleep.
 Share
    • Installed  Nismo coppermix twin competition spec last year in my bnr32 with pull trans with Oem slave cylinder. The point at where the clutch disengages/enages is right at the top of the clutch pedal, meaning I barely have to push the pedal down for the clutch to be disengaged.  You guys that have the same combo are you experiencing this high pedal bite point??   Secondly I’d like to have the disengagement point lower meaning I have to push the pedal more(further not effort)for it to be disengaged.  I’m thinking to use a Nismo big operating cylinder(bigger bore at 13/16 vs Oem 3/4) which will require more pedal stroke to get the equivalent movement at the clutch fork. But I see Nismo web site says not to mix these 2 as the Nismo big operating cylinder doesn’t have enough stroke to disengage??? Any folks run both the coppermix twin pull with Nismo cylinder??    Thanks in advance for the replies but prefer only guys with pull clutches to respond. thanks
    • Any chance u could let us know where your based ?
    • That’s a great deal and I would jump on it if you were closer. Melbourne is a bit of a hike for me though unfortunately
    • I wonder if there is much to tell without knowing where the bolts where bought from. If it comes from Amazon or similar all bets are off. Can't trust them. And I fear not everybody knows that. Wasn't it @TurboTapin who ended up with the fake fuel lines recently? The submersible ones which very much weren't submersible at all. It kind of applies to everything nowadays. Doesn't matter if it's hardware or electronics. The fancy camera might have internals swapped out for cheap knockoffs. The hard drive will report a certain size but not actually be able to write it all. Shit like that. A bit depressing but the reality is you really have to be weary of where and how you buy stuff
