how much? will they fit in the single DIN position under my stereo???
are they out of a r33?
They'd fit in a din sized slot easily, the main thing you have to find out is if the cables are there for them to plug in - integrated GTR gauges get their readings from the ECU, not an independant sensor. My GTR's centre gauges have two plastic plugs that clip in to the back, not sure if those plugs are there on 33's and 34's or non GTR's
-D
need $100ono to go towards new tyres on the front of my car as they are forked.
yes its single din , i had em in my skyline just to fill the gap between my air con and fold out screen
yes they are from an R33
as Dohmar said above^^^^
do u have the plugs for them???
i'm not gonr hook them up 2 my ecu, i just need the plug to have the pos/neg/illumination wires, thats all ill hook up
by the looks of it, in a GTR it must of been where the climate control was coz the right side has no corner so if i fit it under my stereo there will be a slight gap
nah dont have any plugs , just the unit its self
here is my stealth ute shes a monster now with the black sunnies and truck pipes, wonder how long till the cops pull me over bout it. :)
keep a look out for this at glandambo 4x4 event if anyone here goes to it you might see me there this year. im gunna jump the table top and land in the mudpit, hopefully land on all fours.
on another note is it illegal to have your cam gear cover off as i want to get some purdy red cam gears.
have u got a tray on the back of that? can guarantee with no tray or protection over the rear wheels you'll get looked at, but otherwise id say it'll be stealthy :)
    • Unless you have big cams, there is no reason for an RB to idle at any more than the stock 650. No, it is not 850, 950, or anything else. It is 650. In fact, it might even be 550. I just opened an arbitrary stock Neo file in Nistune, and this is what I see
    • I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
    • I think a scissor lift is better/faster in most cases, but I guess it does obstruct access to the centre of the car? BTW I weighed the quick jack. 3.5 tonne model is 50kg for each side. So yes, portable, but not with one finger
