CRoNic... Posted January 7, 2009 Share Posted January 7, 2009 Lol Damo, I got 47%... I didn't even understand it! Link to comment https://www.sau.com.au/forums/topic/188416-the-sa-wasteland/page/863/#findComment-4354646 Share on other sites More sharing options...
CRoNic... Posted January 7, 2009 Share Posted January 7, 2009 (edited) That's a pretty good result, Mitch. Considering stock standard RB26's will pull between 170kw and 180kw at the rears with the 4WD fuse taken out (R32's) on stock boost (meaning the restrictor still in). Mine pulled 174.6kw at the rears on stock boost (the GTR still has the stock boost restriction in it! Never been touched), stock turbos, 3 leaking injectors (found that when it was on the dyno), a collapsed centre muffler baffle and a stuffed cat. No ecu mods, no EBC, stock intercooler... only mods are twin Blitz pods. Pretty good result! And the engine is in good condition (170psi across all 6 on a compression test, leak down test proved it's healthy, too). Once I've replaced the exhaust with a full new system, I'll put it back on the dyno and see what I get. The injectors have already been fixed. My exhaust is that badly clogged, that I can expect to see a large difference (like, 20kw or 30kw extra lol). Mitch, What do you mean you've modified the coilpacks? If you've ripped out the stock coils and put in Splitfires thinking it'll improve performance... you've wasted your money. Nissan Standard Coilpacks are the best you can buy... Splitfires are a cheaper alternative. Edited January 7, 2009 by CRoNic... Link to comment https://www.sau.com.au/forums/topic/188416-the-sa-wasteland/page/863/#findComment-4354665 Share on other sites More sharing options...
Damo_R34 Posted January 7, 2009 Share Posted January 7, 2009 yeah it doesnt really explain itself all that much. you have to determine if the argument is logical. a hint. All ducks quack donald is a duck therefore donald quacks. It states that ALL ducks quack, and Donald is a duck, so it as a valid argument. Link to comment https://www.sau.com.au/forums/topic/188416-the-sa-wasteland/page/863/#findComment-4354666 Share on other sites More sharing options...
Madaz Posted January 7, 2009 Share Posted January 7, 2009 Dont worry i got 60% but i call shananigans on that test Link to comment https://www.sau.com.au/forums/topic/188416-the-sa-wasteland/page/863/#findComment-4354690 Share on other sites More sharing options...
Damo_R34 Posted January 7, 2009 Share Posted January 7, 2009 err, why? Link to comment https://www.sau.com.au/forums/topic/188416-the-sa-wasteland/page/863/#findComment-4354703 Share on other sites More sharing options...
rhys5169 Posted January 7, 2009 Share Posted January 7, 2009 I agree steve my mates GT went from 224 at Aussies to 257 at KPM with the addition of underdrive pulleys only (which in reality would be 5-10rwkw at the most). Hows your car doing mate got it sorted? had my car dyno'd at MRE, then 2 months later no more mods done got a reading at KPM that was 20rwkw higher :s Link to comment https://www.sau.com.au/forums/topic/188416-the-sa-wasteland/page/863/#findComment-4354714 Share on other sites More sharing options...
CRoNic... Posted January 7, 2009 Share Posted January 7, 2009 Rhys, how many kw's did the GTR make? Link to comment https://www.sau.com.au/forums/topic/188416-the-sa-wasteland/page/863/#findComment-4354754 Share on other sites More sharing options...
rhys5169 Posted January 8, 2009 Share Posted January 8, 2009 nooooo idea, different car lol Link to comment https://www.sau.com.au/forums/topic/188416-the-sa-wasteland/page/863/#findComment-4354895 Share on other sites More sharing options...
CRoNic... Posted January 8, 2009 Share Posted January 8, 2009 Oh lol. Yeah dyno readouts seem to be different from dyno to dyno! Link to comment https://www.sau.com.au/forums/topic/188416-the-sa-wasteland/page/863/#findComment-4354906 Share on other sites More sharing options...
DamageInc Posted January 8, 2009 Share Posted January 8, 2009 That's a pretty good result, Mitch.Considering stock standard RB26's will pull between 170kw and 180kw at the rears with the 4WD fuse taken out (R32's) on stock boost (meaning the restrictor still in). Mine pulled 174.6kw at the rears on stock boost (the GTR still has the stock boost restriction in it! Never been touched), stock turbos, 3 leaking injectors (found that when it was on the dyno), a collapsed centre muffler baffle and a stuffed cat. No ecu mods, no EBC, stock intercooler... only mods are twin Blitz pods. Pretty good result! And the engine is in good condition (170psi across all 6 on a compression test, leak down test proved it's healthy, too). Once I've replaced the exhaust with a full new system, I'll put it back on the dyno and see what I get. The injectors have already been fixed. My exhaust is that badly clogged, that I can expect to see a large difference (like, 20kw or 30kw extra lol). Mitch, What do you mean you've modified the coilpacks? If you've ripped out the stock coils and put in Splitfires thinking it'll improve performance... you've wasted your money. Nissan Standard Coilpacks are the best you can buy... Splitfires are a cheaper alternative. yeah im not saying its a performance mod, its the only thing thats been changed on the motor its self Link to comment https://www.sau.com.au/forums/topic/188416-the-sa-wasteland/page/863/#findComment-4355174 Share on other sites More sharing options...
DamageInc Posted January 8, 2009 Share Posted January 8, 2009 oh and i also got a fine for "failure to maintain vehicle" yesterday , they f**king know when to kick you when your down *shakes head* Link to comment https://www.sau.com.au/forums/topic/188416-the-sa-wasteland/page/863/#findComment-4355201 Share on other sites More sharing options...
Madaz Posted January 8, 2009 Share Posted January 8, 2009 Dyno readout's differ due to different shoot out modes used the amount of brake that is used to simulate road conditions damo will post my thoughts later when im home about that logics test Nozila - where did you get defected Link to comment https://www.sau.com.au/forums/topic/188416-the-sa-wasteland/page/863/#findComment-4355191 Share on other sites More sharing options...
rhys5169 Posted January 8, 2009 Share Posted January 8, 2009 mitch, a cop pulled you over and issues that? Link to comment https://www.sau.com.au/forums/topic/188416-the-sa-wasteland/page/863/#findComment-4355234 Share on other sites More sharing options...
Madaz Posted January 8, 2009 Share Posted January 8, 2009 What did they see you were over due on an oil change Link to comment https://www.sau.com.au/forums/topic/188416-the-sa-wasteland/page/863/#findComment-4355217 Share on other sites More sharing options...
DamageInc Posted January 8, 2009 Share Posted January 8, 2009 mitch, a cop pulled you over and issues that? yep , pathetic if you ask me but hey, he was nice and liked my car and wasnt out to defect me , just sucks being unemployed at present and having to pay this fine and get new tyres , but oh well least i can still drive Link to comment https://www.sau.com.au/forums/topic/188416-the-sa-wasteland/page/863/#findComment-4355251 Share on other sites More sharing options...
Damo_R34 Posted January 8, 2009 Share Posted January 8, 2009 yeh flick said her uncle or someone saw an orange 33 getting picked on. Didn't you wash it this week or something? Link to comment https://www.sau.com.au/forums/topic/188416-the-sa-wasteland/page/863/#findComment-4355243 Share on other sites More sharing options...
DamageInc Posted January 8, 2009 Share Posted January 8, 2009 What exactly was the fine for? because they only check the outsides of a tyre and i had mine rotated last week cause of camber wear when in actual fact there is perfect tread on the tyre Link to comment https://www.sau.com.au/forums/topic/188416-the-sa-wasteland/page/863/#findComment-4355269 Share on other sites More sharing options...
(OO)Firty Free(OO) Posted January 8, 2009 Share Posted January 8, 2009 had my car dyno'd at MRE, then 2 months later no more mods done got a reading at KPM that was 20rwkw higher :s Yeah i was thinking of taking mine there to see if i could squeeze 300 out of her Link to comment https://www.sau.com.au/forums/topic/188416-the-sa-wasteland/page/863/#findComment-4355253 Share on other sites More sharing options...
Damo_R34 Posted January 8, 2009 Share Posted January 8, 2009 yep , pathetic if you ask me but hey, he was nice and liked my car and wasnt out to defect me , just sucks being unemployed at present and having to pay this fine and get new tyres , but oh well least i can still drive What exactly was the fine for? Link to comment https://www.sau.com.au/forums/topic/188416-the-sa-wasteland/page/863/#findComment-4355261 Share on other sites More sharing options...
CRoNic... Posted January 8, 2009 Share Posted January 8, 2009 Luuuuuuuuuuuuucky no defect, Mitch! But failure to maintain vehicle = demerit points, too? Link to comment https://www.sau.com.au/forums/topic/188416-the-sa-wasteland/page/863/#findComment-4355385 Share on other sites More sharing options...
