mm turning 21 was good, my insurance premium has dropped by $600 for my next year :) but my agreed value has dropped $2k :)
it wouldn't be cause you turned 21 that your insurance dropped its because the agreed value has dropped
.7
you generally wouldnt need to go any lower
Damo - that logic test, 1 of the questions i didnt like was #5
Answer 5.
a) Where there is poverty there is crime.
b) There is crime in Camberwell.
- Therefore there must be poverty in Camberwell.
Invalid. There may be crime where there is poverty, but it does not necessarily follow that wherever crime is there is poverty. There is plenty of crime occurring in wealthier circles.
where there is poverty there is crime is a truth statement its not guessing
there is crime in camberwell is again a truth statement
so how can it be invalid where not discussing how wealthy camberwell is just stating there is crime there
sweet..can they go lower due splitfires?
Ideally want a higher gap not a lower. I higher gap gives a better ignition to the fuel but it also is weaker spark which makes it susceptible to being "blown out" by the intake charge.
Anyhow the accepted gap is 0.8mm if you have split fires then you should be able to run a bigger gap but it'll be trial and error to find out how big and I wouldn't go over 1>1.1mm anyway.
Edited by D_Stirls
hmmm.... ok i think there at .8 atm... thats wat they are from the box?
i can just feel the car hold back constantly then be ok the hold back due to missing...
ill open them up more... trial and error i guess..
what is the last number on the part number? If it had some thing like BKPR6ES-8 then it is 0.8 but if it was -11 or didn't have a number at the end then it's 1.1mm
If you are having spark problem then opening them up won't help you need to close them up, but if you have split fires then you shouldn't be having spark problems. you will know if they are breaking down because it'll sound like it not running on all cylinders where as you are saying it's feeling like it's being held back which isn't spark. It's probably got more to do with ignition timing.
Edited by D_Stirls
Surely dropping my agreed value from 23,900 to 21,850 wont bring my insurance premium from 2098 p/a to 1500 p/a. if thats the case, ill set agreed value at 18k and pay no insurance.
Rhys, yep just car, got the info from my policy renewal letter, expires early Feb.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
