The Sa Wasteland
Cubes
 Share
Had a quick look at RB26 results: try this
18psi with high flowed steel wheels = 280 odd kws
18psi with -5s = 316kws .........
Only had a quick look - maybe there are others making more power on high flow steel wheels?? Post em up if you find them.....
334kw at 1.1 bar and pretty safe AFR's........with -5's stock cams & internals
A little more boost would've seen 350/360kw easy.
yeh its all internal man that why im getting mine hi-flowed atm
Hi flo is the way to go atm. Too much police attention otherwise.
Had a funny time last night with a handful of cops. At a breatho, and the cop had to ask about my bike, then more cops come over and for 5 minutes I'm talking to 4 cops about how fast my bike is :3some: I did ask "is this you as a cop asking or you personally asking?". Cop was right into bikes and would have talked all night. Had I been in the Stagea however .......
Yeah I think that'd be ideal, but do u know any place that can hiflow and steel wheel some stock 32's for the same price as some new garrett 2860's ? ;\ I wish I knew of such a place.... street legal ftw
(Tho having said that I'm really hanging out for nationalisation of the vehicle standards scheme)
-D
cost come into die grinding out your internals Ben its not just a matter of changing the center cartridge and put steel wheels in and away you go there is a lot of work involved
i forget what thread it was now but someone asked if there was any visual difference and yes there is, wont go into details for obvious reasons
But $1250 ea is still uber expensive.... 15 hours of work at $80 per hour... does it seriously take that long?
-D
Yeah, I honestly think hi-flow or not, they will ping you regardless. I've seen a hi-flow and standard turbo off in my hands and I can definately tell what's what. As Steve said, not going into details but they are there.
It's not only the labour, it's the cost of the new cartridge and wheels also :3some:
SO
my engine seems to be f**kED :down:
has basically no low end power , shoots carbon water , missfires like a bitch , radiator fluid has particles of crap in it
seems to me its blown a head gasket though it doesnt blow bubbles through radiator when thermostat has heated up ??
its shitting me to tears , any clue's as to what would be causing this ??
have u also checked under the oil cap?
the head gasket might be flowing water into the oil
if that looks like iced coffee = BHG.
know this all to well from blownig a few 7m's in my old cressy (they dont seem to like high compression)
 Share
    • Have you adjusted the clutch pedal rod? You can wind it in to shorten it. Just can be a cnut to get to.
    • Yes sir, that was me. Fake ARP's are also a thing over here in Canada and we only order from reputable dealers. It's sad that even simple things like bolts and hoses are now also being copied... anything to make a dollar.  Story time. Like all cheap crap from China, it's even an issue with firearms. Roughly 15 years ago, I purchased a new cheap Norinco 12g shotgun. First time out in the bush with it, while firing, bolt assembly didn't lock and it fired out of battery. The receiver also being cheap steel, basically exploded in my face. I was lucky to be wearing eye protection. Long story short, don't buy Chinese junk. Also Norinco being state run and their only military arms producer, if ever they do try and take over a country, don't worry about it lol.
    • Installed  Nismo coppermix twin competition spec last year in my bnr32 with pull trans with Oem slave cylinder. The point at where the clutch disengages/enages is right at the top of the clutch pedal, meaning I barely have to push the pedal down for the clutch to be disengaged.  You guys that have the same combo are you experiencing this high pedal bite point??   Secondly I’d like to have the disengagement point lower meaning I have to push the pedal more(further not effort)for it to be disengaged.  I’m thinking to use a Nismo big operating cylinder(bigger bore at 13/16 vs Oem 3/4) which will require more pedal stroke to get the equivalent movement at the clutch fork. But I see Nismo web site says not to mix these 2 as the Nismo big operating cylinder doesn’t have enough stroke to disengage??? Any folks run both the coppermix twin pull with Nismo cylinder??    Thanks in advance for the replies but prefer only guys with pull clutches to respond. thanks
    • Any chance u could let us know where your based ?
