Over the holidays:
changed plugs and did oil change and coolant change
removed the HKS filter and refitted the stock airbox
removed boost gauge
put Apexi gear up on ebay ... not fitting anymore
removed adjustable and got ride height at 375 front (340 ADR) and 375 rear (340 ADR)
tested exhaust system with cat/box resonator/muffler and its quiet at 88dBA
Should keep the officers happy :P
Also ... I drank lots of beer ... and sold my GSXR race bike :P ... and got a buyer for the Stagea looking at it this week.
I'm approx 380-390 all round... yuck.
wow, and people say im rocking the 4wd spec height.
also, im now home sick. f**k. how disgusting are people that think its ok not to bath and simply cover up their disgusting odour with perfume? had a punter like that today, the smell made me physically ill.
What you going to do then Mitch? Get a motor out of a half cut or full rebuild?
just gonna piss and moan about it for a couple more hours , continue to job hunt , get a job , save up cash , fix it , sell it , move on
but for the mean time , let the car cool down then start pulling the engine apart .
They can be an expensive habit when things go wrong but don't let it get ya down mate!
im trying not to but it slowly is considering how much i owe on the car and all that shit
oh well , least its my car and not my health .
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
