There's alot of talk of cranking over an engine without actually starting it to build up oil pressure.... noob question, but how do you do this?!
Unplug your crank angle sensor mate and crank it with the key, it will crank over but not fire, hopefully building some oil pressure....it probably wont build enough to read anything on the guage however...alot of people do this when a motor has been rebuilt and they need some sort of oil flowing through so they know the oil pump is primed.
Ok just got back from Dyno. Boost controller having trouble holding boost as it spikes to 25psi and by the end its at 19.5psi.
1st Run wheel spun its titties off so Pete had to tighten the straps more (made 279)
2nd run right up the top off the torque range it lost traction again and the graph fell away (made 323.8)
3rd run the heat had set in but still managed 323.2 and still wheel spun a touch up the top of the torque.
If i can get the boost to hold more stable who knows possible. I will post the dyno graph in the RB25 upgrade thread sometime today.
I owe all this to AD (aka180or200)who has done an absolutely brilliant job on tuning my car. Your a legend mate.
Needless to say i'm stoked with the outcome.
Loving the new found torque also
luke when ur 25 its even cheaper :)
i hate this dam weather so hot
and im still waiting for my bitch to get back so i can put her new shoes on my 360rwkw 4door build up track/drift mainly no more street car for me
P.S got back from wallaroo and caught some small snapper etc was nice there if i had my car back i would have taken it to 1/8 lots of squid snook gar tommy ruff and sharks etc.
got 50 pound braid on my snapper rod and the dam big arse snappers snapped my 50pound braid lol.
what would this fetch if i were to sell it the way it is ,
not exactly sure whats wrong with the engine but it still runs
stats
ENGINE:
RB26DETT conversion
RB26 sump w/transfer case sliced off
RB25 engine mounts
RB25 Harmonic balancer
HKS Intercooler with custom front mount position and solid piping
BLITZ 80mm S/S tuned front pipes
SIGNAL S/S (1.1mm and 7kg!) rear 80mm straight through carbon muffler
HKS Pod filters
Splitfire coil packs
TODA Racing clutch
TODA Racing 4.5kg Flywheel
CUSCO 2 way mech diff
IRIDIUM Plugs - 6's
R33 GTR fuel pump
SUSPENSION / BRAKING AND HANDLING:
SELBY rear 28mm sway bar
RACING GEAR coilovers
D1 rear camber arms
D1 HICAS lock
CUSCO front tension rod
Solid rear subframe bushes
D1 adj castor rods
PROJECT MU Slotted front rotors
TRW (LUCAS) brake pads all round
NISMO Front strut brace with brake stopper
GTR rear strut brace
BODYWORK & INTERIOR
Full body respray in Blood Orange
Satin Black bonnet and wing
SPARCO bonnet pins
NARDI Steering wheel
TRUST gear knob
SPARCO Spirnt drivers seat w/ BRIDE Rail
GReddy Profec B Spec II boost control
GReddy Turbo Timer
New Carpet
GReddy Boost Gauge
btw its my car AS IS , make me an offer , might be inclined to sell it .
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
    • These arrived today! Sadly I'm going to probably be smart and enjoy the car as is over the summer/sunny period and save the ~2 weeks downtime it'd take to swap the heads over and tune later in the year. Maybe. It's going to be pretty damn tempting seeing these bolt on funs just sitting in storage when they're ready to go. There's a non-zero chance I end up @The Bogan'ing it.
    • MZ11 Toyota Soarer in Iwata, Higashi Osaka
