Had a wheel alignment and puncture repair done at Adelaide Radial Tyres at Ridgehaven, corner Lower North East road and Hancock Rd. Excellent service, i was a walk in and they did it on the spot for me. $65 for a 4 wheel precision alignment and $25 for a puncture repair, had a screw in my tyre and didnt even know. Big +1 for them!
yeah he was telling me about the Holden Hill shop. They also sponsor a "josh" with a drift car? Also a distributor for Maxxis, 235/45/17 Maxxis Victra i-Pro retail there for $225 fitted and balanced. Wanted a printout of my stats but they haven't hooked the printer up to the new machine yet :D
Yep I got a couple of Maxxis tyres from Daryl last Friday. Always good, and prompt service.
Oh, and it is just North East Road, not Lower - that is a different road entirely.
does any one here have a r33 stock turbo elbow i can borrow or buy i need one to get my car back on the road and to get it tunned and i havent got much time 2 do it in even if i borrow it to get it tunned then my car sits till i get another one lol
yeh, i had the mistake of sending mine away with the turbo that was 'supposed" to be highflowed but didnt happen so now i got the gt30 highflow i need one again and ill b done
borrowed adrians (rad 32's) rb20 stock one hoping it would fit but a tiny bit smaller. thanks again adrian
I have one that I bought on eBay that I was going to use on a T2 turbo, but they are a different size. you can have it for the $40 that I bought it for.
niiice! adelaide radial tire are awesome been deeling with them since i was 16 when they had their old old store near golden grove.. daryl is always a pleasure to deal with. now im dealing with i think its mathew near holden hill. awesome bloke! currantly setting my R up with front and rear camber arms, castor arms, all bushes replaced, hicas lock and semi slicks!
+ 1 for adelaide radial tyre
    • Yeah, well, it's not as though anyone is ever going to buy one of those noisy f**kers and put it into a new installation when there are better pumps that are near silent for less money from Ti.
    • I'd suggest having the engine builder listen to it, especially if they assembled it, and minimise how much you run it in the meantime. It may have a serious issue like a big end bearing from the description and I assume the rebuild was not cheap
    • Quite right, typing without checking, it is an 023 which was effectively the replacement for 040 (not that I could find either of them on the Bosch motorsport AU site), and it has a mesh inlet at the bottom of the pump rather than a separate filter
    • Hmm. I should have thought of the clutch bleeding issue. It should be #1 thought for "can't select gears". As to "sounds like the top".....have you actually gone out with the stethoscope and tried to pin it down any more than that? And, buy or borrow a timing light, and set the timing properly.
    • I donโ€™t really have any ideas how to set the timing on the CAS ๐Ÿ˜‚, sounds like the top, sounds like it maybe misfiring as well as ticking,ย  got the box sorted ๐Ÿ˜Œ, must of been a air bubble on the clutch side
ร—
ร—
