The Sa Wasteland
Cubes
 Share
i must be the only person on here actually driving their car today.
I drove today!
Bloody coilpacks. started to run on 5 :( need to get a new set, ne one got a spare liying around buy any chance. Sick of the 32 sounding like a rexxy
Here it is i think.
Sweet chad thx, and cheers for the tip steve. I made it home without any issues so I'm guessing it was just a dodgy afm. time to get my spares reconditioned methinks
-D
Anyone actually heading to BDO ?
nothing really special this year.
prodigy, hot chip, and a couple others will be good.
good perv, and always a big day out.
Cog are playing, theyre pretty damn good... listening to em now - I'd go, if it wasnt so hot and I wasnt working
-D
yeah cog are good. butterfly are ok too.
like em. but dont love em.
Thought u mighta heard of hot chip ?
Im pretty sure you were the dude I spoke to about boards of canada , art of noise etc.?
Anyone up for a late night drive tonight (like 11-12), Just fitted some new pads (750 degree pads for Mallala) and need to bed them in and it too hot during the day. Nothing too energetic as i need to get my car on the dyno to check the AFR's after the last few changes.
Just PM me if your interested and i'll get back to you around 10.
Meeting up in the NE preferably or centrally if there's interest.
Edited by D_Stirls
this is beyond a joke.
this is our 3rd power cut since 5 pm yesterday.
and our 2nd today, power went off at 1, come back at 5 only to have it back off ten mins ago..
once again FUUUK YOU ETSA!!
thanks for yet another sleepless night.
campbelltown... wierd thing is, its not as many houses as last night, and the street lights
are still on :) (last night they where off...
still, either way i look at it, im hot, and this sucks major cock!
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
