The Sa Wasteland
Cubes
 Share
have a look in the radiator, if there the level in there is fine (down around 1-2cm) then just top it up with distilled water and the same with the over flow tank.
Yeah pretty sure the radiator is fairly full as I only checked the coolant a month or so ago and the overflow bottle still had something in it, just over the last few weeks it must have used the rest up.
So don't even top up the overflow with coolant, just use water?
I gave them a call there open till 4.00
I got a note on my font door saying that they try'd to deliver something to me today, i think it might of been my new Brake pads :D so i have to go pick it up after 2. i didn't know they delivered on Saturday's.
You can top it up with coolant if your 100% sure that you have the same brand and make of coolant that is already in the engine. If you mix active ingredients there is a chance that they can react and will turn to jelly, which isn't a good thing the have in your water jackets. Water is a safe option if your not sure since you are going to be changing it soon.
Thanks mate.
EDIT- If it just so happens to turn to jelly, what would I do about it? Just flush the radiator?
Edited by muirsky
i missed pendulum to see lupe, was still amazing but yeh prodigy was insane, like 15,000 people all going nuts when the bassline hit for smack my bitch up
+1 eye candy.
pendulum were good.
but I thought prodigy were kinda average to be honest.
They talked way too much shit instead of letting their good tunes do the work.
Some of the nice sounds and basslines were spoilt because of the stupid screaming etc they were doing.
good day out tho... :P
 Share
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
    • People just don't understand how good MX5's actually are and how fun they are to drive, park, manuever. You feel like you have got some fun cheat code, while everyone else is sitting in their luxobargeSUV like normies who missed the point of living. It really is that noticable. As long as you/your stuff fit, and you're comfortable (they are), a MX5 is the best car on earth to daily around.
