Question,
Just put my coilovers in. I had a wheel alignment done about a week ago, so my question is, do I need another one?
Took the car for a drive and it seems to drive as straight as before.
Question,
maybe you do! my car went straighter with coil overs in but the result when i got it alligned said otherwise
what sort of coil overs did you get?
I might just as well go and get one anyways.
I got a second hand set of Bridgestone NPG's in mint condition. The ride feels very firm but not too bad over bumps either. Only problem is they're set pretty low and I don't have the wrenches to raise the car up a bit.
Edited by tx3_90
they feel good?
what sort of settings can you play with?
WOOT 1000 POSTS !1!111!11!!!111!!
Try this
already been on it mate , also found another removal guide in pdf form but they all show removal with the gearbox
is it possible to remove the engine and leave gearbox in the car still ?
also , wheres the best place to get an engine hoist and stand for a reasonable price?
cheers
I'd be interested in the PDF, could you link me to that?
Why you keen on removing the motor yourself? Save costs on rebuild?
here it is
its for a 32 GTR but i cant imagine it being all that different ?
yeah , i cant afford to take it somewhere to get rebuilt so me and my dad are gonna do it our selves :sick:
Nah, should be pretty much the same!
Old man ever rebuilt a motor before or you going in blind? Be careful and make sure you do some research before you start. A mate of mine did his 25 himself having never rebuilt a motor before and did a great job on it!
    • Done about 5k Km on the PS5's now, excellent street tyres, great in the dry, and the wet, seem to be wearing very well, I haven't measured tread depth, but it looks like minimal wear, I also had a different alignment done about 1500km ago,  From looking at the tread wear, which is really only minimal, the alignment changes were based off how the tread looked, and how it felt throwing it around, the changes have shown great results 215/45 17 at 32 psi Front Caster: 5.5° Camber: -1.5° Toe: 0.0mm Rear Camber: -1.0° Total Toe-in: 1.5mm I actually prefer PS5's now over the RS4's, as the PS5's are much better in the wet IMO, and as the MX5 gets driven in all weather conditions doing daily duties, hwy trips, and blasts in the mountains, wet weather grip is high on my priority list
    • To update this thread. I got sent a replacement Attesa pro unit and all is now working as expected. Cheers
    • FD is so sexy she can pull off tri-spokes
    • Indeed they do. Best my diff builder could tell is it's a combination of the different cut/angle and it would seem they lap them in well on accell but less so on decel. He had to use a slightly different pattern to the lap to get the best result noise wise. Also as the rear diff runs in, the whine is getting less.        Overall they seem like a good thing so far. He's done a few neat crown/pinion before but all for race cars with loud everything, in most cases the exhaust is louder, so I am the first to notice.... and be somewhat of a pain
    • What do you mean by "test"? It sounds like you're just switching things on and off that you already know don't work. Get the wiring diagram and a multimeter and start looking for power where there is supposed to be power and earth where there is supposed to be earth. Look for continuity across switches that are otherwise unresponsive, etc etc.
