Went to the Monster Trucks last night; free family ticket. Glad we didn't pay. :S
Extremely disappointed with the show. WEAK is the word. :(
Wayville showgrounds is a terrible venue to host Monster trucks as they are not allowed to rip up the grass so they are stuck to the outer ring which has limited space so no decent jumps races etc.
One rolled it which was cool to watch but apart from that it was an extremely weak show compared to MT events held at other Venues. :)
Was Grant Denyer driving the trucks? :D
first time out at lala in the new s13 for me and my mate (co-owners)
was so much fun! spund out heaps and the under carage might have a few more dings init thanks to the ripple strips but was still awsome fun!
cant wait to go back out there again!
Edited by Import S13
I must say i was expecting more at Monster trucks.... but i still loved it!!!! the demolition derby was funny as!!!!
as a retired demo drive there more too be in than watch lol .
iv been in about 6 or 7 of them back in the days when v8 falcons and full chassis toyota crowns was the go . i even totaled a studibaker lark in one lol . ive been rolled crunched and had one catch fire but never won one was the second to last car running in one but got pounded in too submission lol . watched one up murry bridge speedway the other week a guy come out in a vn commy wagon it lasted 2 hits b4 the front end fell out of it .
I know alot of you arent really into cricket.
Im buying a MRF bat from india. real with mrf hologram.
anyone used these bats before ? I know they are thick. but I hope they arent too heavy.
watch out buying from overseas, unless its from a reputable dealer. often bats can be held in customs and need to be fumigated etc, and youll get the bill!
Yep I heard about that.
This bat will pass through so they say. Australia is one of their biggest buyers so I think they have it all down pat.
clutches never just shit them selves, every clutch ive done has had 1-2 months worth of driving in it
Haha my old button clutch did, was working fine, then all of a sudden i took off in 1st and it wouldnt go into second, clutch was farked.
DRIFT
Sat 14th February 5pm
Sat 14th March 5pm
Sat 18th April 5pm
Sat 9th May 5pm
Sat 4th July 5pm
Sat 22nd August 5pm
Sat 5th September 5pm
Sat 17th October 5pm
Sat 28th November 5pm
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
