craig if u want a set i can get them for around $1350 del.. without tyres..
Nice.
They jap made ?/
I really like my wheels.; jap made etc. but they are alittle small for the 34.
think those rims are a perfect fit.
IBTL?
I know what it means. I know when it's used. I just don't see the point. It is a blatant whoring post. Are kudos given for a IBTL post? Does it mean that you are so wise that you can tell when a thread will be locked... and... decide to contribute nothing other than raise your post count.
I just don't get it :thumbsup:
^^^ David, for some bizarre reason, many members on here take pride in having a high post count, and posting IBTL just gives them an extra post.
I really have no idea why someone would be proud of being a whore and wasting every ones time (some days I get home from work and have over 200 new post notifications in my email to go through - 90% of them rubbish posts), but therein lies the genesis to your question.
I would rather make a few hundred useful posts than 10,000 useless posts, that is for sure. In fact I think my post count is around 3,000 and I have been on here around 7 years :) - some people have tripled my post count in 1 year .... sad little men .... :thumbsup:
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
