Here's a good one for you all:
If a cop writes out a expiation notice for a offence committed by a person sitting in the back seat (passenger) yet writes on the expiation notice that he was the driver AND passenger... and then gets another warning in the mail saying he's now even the owner of the vehicle in question (yet he's the passenger of a mates car)... what can you do?
Also have to note, that the evidence against the passenger (basically the notes that the cop took down) is literally unreadable scribble. You can make out 2 words in the 8 lines he's written. Nothing else is readable. Even lawyers deem the notes/evidence unreadable.
Is it worth taking to court? Will they just correct it or is it classified as a major error?
I had thought that the driver is fined for the passenger not wearing the seat belt ... is that what is actually in question here? How can the passenger be fined? Its the driver's ultimate responsibility therefore he/she will be the one fined. Would you hand out a fine to a 10yo kid in the back seat?
Correct me if I'm wrong. :ermm:
Edited by RubyRS4
Spotted "aaah31" in the City about 2pm today. :ermm: I was the biker cutting thru traffic ;)
i thought he basically told all of us to f**k off and that hes going back to perth?
Thats right!
Well, he's still in Adelaide :rolleyes:
lol, I must have missed that whole episode......did something happen during the week I was away?
don't quote me on this but I think if the passenger is over 18 they are at least responsible and possibly the driver as well
However if the passenger is under 18, the driver is responsible.
Correct me if I'm wrong :ermm:
Hey guys, yes, this is another one of those "should I buy this" posts from me... I'm sorry but I'm very pedantic when it comes to big purchases like a car.
The car I'm looking at at the moment is here: http://www.carsales.com.au/all-cars/privat...id=11EECA35A9B0
I have checked the oil and coolant, all fine. The guy has reciepts for the services, including the major 100,000km one, done at 94,000ks. Services have been done every 5000ks after that (with reciepts). All that was done at Sinergy.
The speedometer is a bit dodgy, it keeps flicking on and off, but he said that could be easily fixed. The bumper also has a few minor scratches on it, because it is quite low. Other than that, it's pretty clean.
If I do decide to get it, I will take it to a mechanic (Martin Donnon) to give it an inspection
Any comments? Price offer suggestions are also welcome, I'm aiming for $16.5k.
Cheers for your continued help :)
Yep, got defected for my wheels 'hanging out of the guards' but still being in track and legal diameter. That's all he done me for, not to low or loud or ANYTHING other than that. I see that as revenue raising at its finest.
I'll be calling Regency tomorrow morning and explaining the lot to them. The officer even complimented me on how stock my car was! But I still got regency
Whats my chances?
It's 16, Pete!
If you're even 16 and on your L's and get caught in a backseat with no seat belt, you lose 3 points! Regardless what license you have.
Spot on mate
I got done, passed out drunk in the back of my mates company van, sleeping amongst all the tools. Mate got pulled over, I got woken up by a police officer and booked for no seatbelt. Blah!
Martin is not a mechanic, he is a tuner.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
