Morning all.
Good friend at work, she and her husband were driving his late model BMW down the bay last night to find a park to eat. They got pulled over by the cops and got smacked with a $168 fine for having her stock standard fog lights on (the small ones in the front bar near the bottom).
How petty can you get.
There's alot more to the story (only got done for that, but it's the conversation that followed), but since it's a public forum, I won't say any more as she's taking it to court.
Although, I heard in the news that the cops were cracking down on the use of fog lights... but I thought it was only the aftermarket ones? I thought the stock standard ones that came with the car were fine?
now the fooly sick S13 boys wont have theirs on all the time. I heard somewhere that fog lights may only be in when it is actually foggy? but how do you make that a law?
Well the law was passed 4 weeks ago legalizing the use of Fog lights in foggy conditions. Before that you weren't allowed to use them at all.
Thats one of the reasons the regency boys would fail fog lights on most cars, with the obvious exception of stock foglights (not defectable but you weren't allowed to use them legally until a few weeks ago.)
Yeah. Ya gotta love the genius bureaucrats running this state. Bunch of Monkeys...
-D
they introduced a heap of new random driving laws on jan 31? including 'you cant lead an animal while driving a car' and 'you have to return number plates of unregistered veichles before they have been unregistered for 90 days'
Edit: fixed, to make sence
Edited by Fishpaste~
Yeah my mate got a $180 dollar fine for having his fog lights on one morning (wasn't dark enough for headlights but wasn't light enough to drive around with nothing on either). Cop pulled him up and treated him like he just murdered someone saying if he was behind someone it would impair their vision or something.
my mate still has his plates from at least a year ago lol. custom plates, transport SA harassed him for ages then just gave up sending letters.
and who the f**k holds a leash out the window while their dog walks on the sidewalk? I guess their motto when making these laws is "Cover all bases"
your pretty much on the right track there damo
whats the definition of foggy conditions???
What if you deem it foggy enough to use it and the cop that pulls you over doesnt think its foggy enough???
wtf happens then
wtf happens then
I think you know what happens there Krish
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
