oh yeah
im investigating instant power for my 4wd too
http://www.dieselgasaustralia.com.au
"This Diesel/Gas system will increase power and torque by up to 20% (sometimes more). This power increase is due not only to the increased combustion efficiency, but also the LPG itself produces power as it burns. So even the most economical gas map and driving technique will produce some additional power. A more powerful setting can still produce better economy than running on straight diesel."
"The power and torque increase applies over the whole rev range. Turbo lag is all but eliminated, and engine noise and vibration is dramatically reduced all the way through to maximum revs. The driver will notice fewer gear changes and higher average speeds, particularly on hills and when towing"
and for an equivalent for what i should expect
2002 Nissan Patrol GU Coil Cab
TD42T – 4.2l 6Cyl turbo diesel
5 Speed Manual
80,000km when fitted
Average fuel consumption 15l/100km
Standard Power: (red line)
96.6hp @ 3200rpm
840lbft @ 2600rpm
DieselGas Power (green line):
141.5hp @ 2750rpm (+46%)
1295lbft @ 2040rpm (+54%)
so, turbo people, looking at getting a new turbo for the s14, as the stocker is one its way out. not thinking anything massive, got it down to a garrett GT28R or GT28RS, just wondering if anyone here has any experience with them? ill probably end up browsing the forced induction forum soon, just seeing if theres anyone here whos used either first.
do it matty i wanted to put the skyline on gas but couldn't fit a donut tank in the boot LPG = higher octane than fuel
only problem with gas as i know is that it just doesnt have density and it requires some special injector to force the gas into each cylinder when its under boost.... my r31 had the simple setup, where as the gas is diffused into the air pipe before the plenum, but they aren't sufficient for turbos (and the fact that the lpg burns at a higher temp which could be an issue for some turbos)
-D
Well depends on what your really after Dave.
I have heard of people putting R34 stock turbo on and having a decent power increase by that.
GT2871R isnt a bad option either as i think thats what Dale is running in his 180 and is making quiet nice power.
So really what you want is to find out the maximum for your other parts ie. injectors, afm and etc
and then go with a turbo that wont be maxing those components out otherwise you might as well spend a lot of $$ and get everything done....ie injectors, afm, fmic, coil packs, ecu tuning etc
Hope this helps Dave
cheers krish, completely forgot about dale. shall have to have a chat with him. 34 turbo sounds interesting, thinking lag could be an issue with the missing 500cc though. just looking for nice streetable power, somewhere around the 150-160rwkw mark.
Then for that Dave i would say go with a RB turbo
from what i have heard it reduces lag on a RB20 so it shouldnt be laggy on a SR20 me thinks
good luck with whatever you do mate
I think one of my mates chucked a R34 turbo on his RB20 and made something like 180rwkw with fmic, fuel pump, pod and 14psi of boost
so wont suprise me Dave if you make a significant gain from that mate
lol they should fix the god damn roads
some of the roads around adelaide is absolute shocking
ohh and penny if you pay yearly rego you save something like $100-$150
IMHO thats a lot of money to be saved on rego
well at least thats another months worth of insurance for me really
Yeah I have decided that next time round I will do it for 12 months.
Its just crazy that we have to pay so much just to have a car on the road.
IMO push bikes should have to pay, they use the road too!! not to mention being a major traffic hazard at times.
I should be posting in the what really pisses you off thread huh.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
