:P
Yeah, you know... being driven around to country sites, moving a few PC's here and there... enjoying the big mac I bought from macca's...
Such a tough job :)
umm i used to love it when i was part of the country team
go out to country sites for a week...come back for the weekend
party hard and then go back out to the country the next week
i even got flown down to mount gambier....loved it
That's what I'll be doing soon, Krishy...
Getting paid to fly out to Port Lincoln, Mt Gambier, etc, work, stay in hotels, fly back, party, fly back again
My previous job flew me out to Sydney for a week. Now THAT was awesome. The hotel was insanely nice, and we all got wasted and roamed the Sydney streets at 4am.
When i used to westpac, they used to fly us interstate every weekly lol
that used to be fun...me and mates used to just roam the streets at wierd hours of the morning
with company card and car lol
hotels were all 4.5 star plus...workers demand
That defeats the purpose! hahaha
Wishing my dad kept the Chargers he raced. They would be worth heaps now.
My old boy has a nice charger in the paint shop.
Some of the offers even without paint are pretty impressive.
Who wants a angry Commodore?
I'm not a fan of Commodores, but f**k... if I had one sounding like that... it'd be a totally different story.
man we got totally diff tastes.... cammy is one thing but that thing sounds like anus
i like cams, they naice, they goood, but i couldnt drive that with a straight face :blink:
-D
hi matt, i am interested in the sickers, prices,sized and can you get anything made up
trying to get hold of the bloke, finding out some more costs. pretty much anything made up by the looks of it
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
