so, turbo people, looking at getting a new turbo for the s14, as the stocker is one its way out. not thinking anything massive, got it down to a garrett GT28R or GT28RS, just wondering if anyone here has any experience with them? ill probably end up browsing the forced induction forum soon, just seeing if theres anyone here whos used either first.
cheers krish, completely forgot about dale. shall have to have a chat with him. 34 turbo sounds interesting, thinking lag could be an issue with the missing 500cc though. just looking for nice streetable power, somewhere around the 150-160rwkw mark.
Hey Dave,
If there is nothing wrong with your turbo then I would keep it fit a boost controller and go see Jeff (SpeedLab) for a remap. For around $500-$700 (my remap was around at or below the lower end of that scale but SR's need a daughter board installed which the CA's don't and the board costs around $250 by itself) your current turbo you will make around the 190rwkw mark. I have a feeling that you will be near the limit of your AFM at that point and you won't want to go to much further with your standard injectors, but you should get there.
If you want to go bigger turbo then you will be looking at at least 550cc injectors (but 740cc are the same price and they will give you more scope for improvements in the future improvements) remember that with 4 cylinders you have to go bigger with your injectors to make the same power as a 6 as there are less of them.
You will also need to a bigger AFM; once again you have choices a Z32 will support around the 320-350rwkw mark but costs anywhere from $200-$300 where as a SII RB25 AFM will support 230-240rwkw and will cost you around $50, and really even if you go for a GT2860RS you won't be making 230kw without cams.
If your still after up upgrade i would suggest the GT2860RS as a GT28R (A.K.A T28BB) is only ever so slighlty bigger than what you have on there from the factory
I would forget about the GT2871R as it's too big for what you are looking for as it will support 230-240kw without cams and 250-260kw with cams but come at the cost of response (full boost at around 3700-4000 depending on cam setup).
Anything else just ask
Edited by D_Stirls
sorry im agreeing with the doh man, sounded like a steam train trying to take off at first and also like it stalled about 6times. crommies also terrible.
if you gonna go v8 go for elenor or gt40 :)
you guy's do realise that it's supercharged as well and that is why the idle is up and down like that.
P.S. i think it sounds absolutely TOUGH, but then i did grow up around BIG V8s.
http://www.youtube.com/watch?v=wJNM3sHcwBY...re=channel_page
See the front mount at 0.24
Edited by D_Stirls
meh i dont care if its got 2000hp it sounds terrible to me,
but ive always been a exotic loving anti v8 type of person :)
although i have developed soft spots for the 2 above v8 mentioned cars and shelby cobra's
I have a soft spot for 1967-1969 chevy camaro's... 1st series... even today they look frigging awesome...
-D
Well you'd hate this thing then cos' it has a dirty old V8 in it ;)
lol now that sounds tuff, has tt attached much like f40s which are also tuff :)
i just dont really like the valliant style box cars pencil ruler design and engines that sound like they stalling or have metal getting chewed up inside.
but thats me feel free to disagree ya'll ;) i drive a rusty dato anyway
Edited by Inline 6
anyone want stickers made up for their cars that have reflective properties? ie the stuff road signs are made from?
like so: 006.jpg
ill take a barracuda. in red.
Hey Dave,
thanks for the advice mate. :)
fairly sure somethings not right with the current turbo, but ill wait til i pull it off the engine and have a good look at it. might just get it rebuilt and tuned.
cheers.
All this talking about ECU remapping has got me curious.
So, it's basically flashing the ECU? Everything on the outside/inside of the ECU is kept standard (eg. no chips soldered to it, etc) except the ROM data?
Would this mean, it's technically a way to get through Regency as opposed to having a Power FC or something else as your ECU?
Yes and no... you can reflash an ECU with another set of firmware which may or may not contain an updated map...
The map is EEPROM which stores a spreadsheet of air fuel ratios and other assorted timings, and is done by using a laptop in most cases, and can sometimes be done without any mods... r32 gtr ecu is reprogrammable but the 33 and 34's arent iirc. Thats one of the reasons people like to switch to aftermarket ecu's like PFC's because of the ability to change heaps of settings..
-D
and, lets face it, chicks dig live readouts on the pfc hand controller.
i dont haz pfc, oldschool gameboy with LAN cord going from gameboy to behind the dash will have to do till the funds allow :P
scandy, 3 spoke rims are made of fail............ IMHO
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
