600ml coke bottle, garden hose, gaffa tape
problem solvered
1 lap around lalla and it'll be full of oil.
you need a proper air/oil separator.
sinful has a good dual can setup.
I would use a partial plumb back can mounted above the cam covers (near the firewall) and a washer bottle replacement can (at least 2 litre capacity) with a plate baffle inside to bend the oil upon entry and a hidden breather under the can. SydneyKid uses stainless steel wool cans to bend oil but they're messy IMO.
here's a setup I was going to use before selling the R:
Primary top mount can with plumb back.
Main can (washer bottle replacement) large capacity with baffle, hidden breather & drain.
Showing hidden breather and dual washer pump fitment.
