ca wouldn't even heat up a kettle :)
but srsly, CA in a keto would be fun, gotta look after the engine tho. 90% of CA's are old and thrashed, no wonder they dont last. If you think about the pre 91 silvias with CA's, that was 18-19 years ago, thats old in engine years.
all aboard the failboat.
http://www.skylinesaustralia.com/forums/To...93-t260430.html
holy shit! someone run this turbo
Garrett GT6041R
Information:
This large frame turbo is suitable for race applications.
Housings Available: 1.25 A/R, 1.47 A/R
Power: 2000hp
The price is still dropping :)
http://www.j-spec.com.au/list/index.php?ID=14119
yep not wrong on that one damo
if i remember correctly he made 185 on the boostworx dyno
not a bad power to weight ratio on that beast
That was 185 kw with a 10mm hole in the intercooler piping where a blanking plug came lose and fell out. That won't be happening again, now with added loc-tight.
What's with all the CA haters here, anyone would think it's a skyline forum. The only problem with CA's is that a lot of them have had a hard life and they haven't been well maintained, If you get one that's been treated with respect they make a good RELIABLE little power house. Have a look at the graph below, that's on a standard bottom end.
Here's the new graph from a couple weeks ago on a 36 degree day, and that's after i lost 10kw by going back to the factory manifold which we gained back by 1 more psi in boost, also gained 400 RPM in response with the factory manifold;
Edited by D_Stirls
such a nice and smooth curve and the power is coming nice and early as well
ahh now i know why you only made 185 on that day....would have liked to see this figure there
so am i reading it right Dale....your actually loosing 400rpm in response by using aftermarket manifolds?
I knew something wasn't right in the day because it was sssooooo rich, if you remember the exhaust manifold was also cracked at the turbo flange, when i took the turbo and manifold off it all made sense when i saw the 10mm plug had falled out of the compressor outlet.
Yep was getting full boost just over 4000 before but now it's more like 3700-3800 rpm, but at the cost of kw. Was making 216kw with the old manifold but with the factory manifold it was making 203kw, with some more tuning and the extra psi or so we got it back to around the same figure as the old manifold.
Earlier power = Torque so would have gained a few Nm in torque, but i don't have a graph with that on it.
Edited by D_Stirls
yeh damo ca in a keto would be a handfull!
CA's don't even need oil :)
Have had nothing but bad experiences with CA's (spun bearings, lack of women throwing themselves at the car when I drove past, etc).
But seriously, if you're going CA... just do yourself a favour and get a RB20!
Use the CA for a paper weight or something.
its ok i thought about rb20 in the keto lol..
but just abit too much work.. and would be way insane!!
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
