And my Optus bill saga lives on!
Here's the bill in question:
06 Feb yes$79 Cap+Unlimited Text 561 KB $0.25
07 Feb yes$79 Cap+Unlimited Text 55 KB $0.02
08 Feb yes$79 Cap+Unlimited Text 8504 KB $3.78
09 Feb yes$79 Cap+Unlimited Text 5 KB $0.00
13 Feb yes$79 Cap+Unlimited Text 9204 KB $4.07
14 Feb yes$79 Cap+Unlimited Text 353 KB $0.14
15 Feb yes$79 Cap+Unlimited Text 45127 KB $612.75
16 Feb yes$79 Cap+Unlimited Text 7392 KB $100.81
18 Feb yes$79 Cap+Unlimited Text 39632 KB $17.57
19 Feb yes$79 Cap+Unlimited Text 23277 KB $10.31
20 Feb yes$79 Cap+Unlimited Text 34668 KB $15.37
21 Feb yes$79 Cap+Unlimited Text 3655 KB $1.62
22 Feb yes$79 Cap+Unlimited Text 156 KB $0.06
23 Feb yes$79 Cap+Unlimited Text 39736 KB $17.63
24 Feb yes$79 Cap+Unlimited Text 96072 KB $42.64
25 Feb yes$79 Cap+Unlimited Text 44736 KB $19.85
26 Feb yes$79 Cap+Unlimited Text 7833 KB $3.47
27 Feb yes$79 Cap+Unlimited Text 3786 KB $1.67
28 Feb yes$79 Cap+Unlimited Text 14452 KB $6.41
01 Mar yes$79 Cap+Unlimited Text 35405 KB $15.70
02 Mar yes$79 Cap+Unlimited Text 19967 KB $8.86
Total volume: 424 MB $882.98
See that in bold? I've been charged at some magical rate for only those 2 days compared to the rest! And when I say magical, I mean... stupid.
Called today, got through to a Aussie (hooray) but... got told "those charges must be legit!" YET he couldn't even tell me at what rate/why I've been charged extreme amounts for those 2 days! It was normal internet usage just like all the other days - not in roaming, etc.
Everything else EXCEPT those 2 days has been rolled into my data caps.
Now it's been raised with the Billing Investigations Team. Sounds fancy but lets hope they know how to do their job.
Edit: and yeah, blah blah blah this is a car forum... but we're all family here.
Edited by CRoNic...
id be quite happy for him to defend the looked after CA's, after all, he has a mean one that would eat alot of RB25's.
and a highly modified RB25 will eat alot of RB26 and a highly modified RB26 will eat alot of Ferraris....
Sorry, I'm always skeptical of things like this. There are no details on it, and it could be anyone's.
Got a print out detailing your car?
That's alright the people that need to know, know the validity. There are no details about my car anywhere online. There is a build thread on NS but it hasn't got any plate/VIN numbers on it and that is the way it'll be staying. Besides the details in the box that I have edited out are entered when you put the car on the dyno anyway so they shouldn't be taken as gospel anyway.
Edited by D_Stirls
And so on and so forth ...
I see, and agree with, your point. :)
yeah your right vu, but for the sake of defending the CA, im saying that they aren't shit engines, the guy behind the wheel over their 18 year life makes them a shit engine, combined with not changing fluids every 5000-10000k's for the last *at least* 5 years.
Hear Hear :)
And here's some more proof;
I dont mind CAs.
BUT. think about howmuch you have to spend just to get it up to RB25s power levels. Also how much you are pushing the engine,
Add as much as you want. IMO id rather a RB thats pushing good power without massive mods.
http://www.skylinesaustralia.com/forums/R3...le-t260355.html
Rims have ruined a half-decent GTR...
But that's WAY to cheap... apart from the body work, I'd dare say the engine is in need of some repair...
my money is on a shagged motor, that thing was for sale by its last owner around a month or so ago, now its back up again so soon.... and atleast 5k cheaper.... seems fishy
Hell for that price, you'd have a few coin left over to fix up the engine.
I agree the rims are ;)
Buyer beware :)
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
