just a word of caution it will be organised at richmond kartmania
and the boys dont like when people are crashing and bashing their karts...
if you are deliberatly seen doing that they will kick you off their karts
What about drifting them? :P Last time I was there I was chucking it into the corner just after the straight as quick as I could and sliding the whole thing as it tightened up :(
Giving the brakes a huge stab coming into the corner after the back straight is a bit of fun too :D
Edited by AndrewJZX100
Yeah I can imagine that'd be grounds for a talking to :P
It was only 2 karts on the track when I was doing so even if I lost all momentum (which is often in the slow Kart Mania rigs) then it wasn't a big deal :D I was just trying to get angles :(
Speaking of Go Karting, anyone been to Greenhills lately?
yeah ive been there older than that youngsta :( do they still have the big bouncy thing? it used to be a lil diff with a harder top making it better for getting crazy air
and yes dont bother with their go karts
Edited by Inline 6
spose its a good thing i was planning on pulling my engine out sometime soon. went down to the local bp to fill up, walking back to the 200 i noticed something dripping, so popped the hood, had a poke around, seem to be weeping coolant from around the turbo.
also had some old codger mumble to me (with my head in the engine bay) on his way past; "stupid hoons, hope your cars broken". :( stupid old codger doesnt even know me...
doesnt seem like much of a big deal though, just need to keep a couple litres of demineralised water in the car just in case.
And here's my "Holy Shit that's a pretty decent car that Uncle Daniel would love to have in his shed" links for the day:
A what?! http://www.prestigemotorsport.com.au/modul...hp?StockID=4727
pantera with a bodykit. would love a pantera, but the 'devil' seems a bit silly, really.
Love the Cosmo: http://www.prestigemotorsport.com.au/modul...hp?StockID=4719
much love for the cosmo. but daily fuel consumption to rival a C-17 globemaster on take off puts me off a little.
Did you reply with 'hey how'd you like to lose a bunch of teeth' Peter Griffin style? :P
yeah ive been there older than that youngsta :D do they still have the big bouncy thing? it used to be a lil diff with a harder top making it better for getting crazy air
Yeah still got the bouncy thing there!
pete get a new tow ornament did he? :D
:(:P
Did you hav ethe aircon on while you were going to the servo? If you did i think i know where the water was comming from.
oh, ive bought a set of pads for the s14 as i can hear the current ones squealing, nothing special, just something to keep my brakes going til i get my qfm's and rda's, but uh... ive never changed pads on 4 pot brakes before, so would anyone be willing be help out?
was going to buy a cosmo prior to the stagea
but couldnt even get behind the wheel - made for small people
tune tomorrow, just a quick little one. cant afford anything atm, bills to pay but no money
so, probably just an hour on the dyno mapping 2nd and 3rd gears, for air:fuel ratios and slight fuel/timing adjustments
got a set of 3-guages to go into a din slot, and the injector setup but no moolah to pay for install, yet
anyone interested in ecu eprom tunes?
eventually want to get a wideband sensor, rom tuner and muck around with mine, learn etc, then offer a service to remap r33's on a local dyno?
theyre pretty awesome... if you happen to own a petrol refinery. if you dont, well, youre screwed.
yeah, the fastest car I've been in was a Turbo rotary with 320rwkw. Awesome engines if you don't break apex seals!
i seriously think a decent 20B on idle would go toe-to-toe with a C17 on fuel consumption. ive driven a cosmo with a full exhaust, front mount, couple more pounds of boost, and i could see the fuel gauge dropping in peak traffic. its f**king crazy.
Edited by scandyflick
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
