From Wheels August 1982
Its CAMIRA: "high flyer, high tech, high time"
rofl, thats everything a camira is NOT. decent work getting it airborn tho :wave:
http://cgi.ebay.com.au/WHEELS-AUGUST-1982-...A1%7C240%3A1318
Wow ... just had a massive project down at Aldinga land in my in-tray. Time to get back to work. Stop talking about my erection and do something about another erection :wave: This is going to keep me busy until the end of the day :P
so, my dad occasionally has fits of awesome.
im at work at the moment, jsut got a call from him, hes taken a half day and is heading out to main north nissan to pick up the feed line i need ($131 including new gaskets for the banjos), and is gonna fit it up as soon as he gets home, i *might* be making the dyno day in my car after all. heh.
but ehm, i removed a few things to find where the leak was, like the outlet snout on the turbo, anyone know what the bolts holding it in should be torqued up to? and what the banjo fittings should be done up to?
Okay, so I'm going to catch the O-Bahn bus today for the first time in like 8 years.
And I'm meant to catch another bus and get off at a place called 'Banksia Park'.
Ah, I hate when some of my mates are Northerners lol. I'm going to get so lost.
Depends which bus you get on to start with.... I know that don't help you much but if you can get on the right bus (I'm assuming in the city) you want have to switch/wait at Modbury
Catching a 542 bus? Apparently that goes from the city right up into Banksia Park.
I'm google mapping that shit up now.
rb20det, gtr injectors, stock ecu remmaped.
put a baffle plate in exhaust..
would that make it un driveable?
i was taking my mates car to regency and all off a sudden, running like a dog, black smoke pouring out..
WTF? prob only hit 2500rpm..
Unless the baffle plate clogged up the exhaust so much, it's causing back pressure and other crazy shit to happen, so the ECU makes it run extra-rich to compensate?
    • Hell yeah. Glad to see it’s closer to the road.
    • Thanks Brad Sheriff. I think he single handedly made the price of NEO heads rocket to the stratosphere.
    • Oh ok that makes so much sense. Thanks for clearing it up!
    • And these modern "environmentally friendly" EV vehicles also run on the same smoke! When the engine, wiring, or batteries let it escape it also stops running!
    • Yeah - I found the same information too.. 30% open is like 85% of flow etc. So it's probably going to be minor if not completely imperceptible. I also have a larger pod filter here, will swap that on and see if there's any difference. The hardest part is finding a place to uh, test this. It's quite noticable just how much having ducting to the otherwise completely open pod cools the intake temps down. It's better boxed, or shielded but driving for 30 seconds really makes it plummet to near ambient temperatures. I recall in the past when I was a RB land and had a nice flowing airbox -  - Then I took the lid off and put a pod there, and gained 9 psi of boost and about 60kw from the restriction I didn't know I had - with the controller at same duty cycle. However finding people using over the radiator intakes having similar KPA drops at WOT on built setups makes me think there restriction could be the exhaust or potentially the headers. Either way though, there's no real estate to play with and nothing that can realistically be done about it. The original dyno plot without the airbox, and the larger pod had a better curve. It was later I added the ducting and airbox, and a smaller pod to make it fit in there...
