went to funkoars tonight. ive never seen so many full blown punch ups in a pit before.
nor have a i ever seen a vn do ringies in a bp forecourt before.
nor have i ever seen star force rock up en masse to a music event.
interesting night.
welcome to the dirty south lol, can garuntee more than half that croud woulda been good ol morphies blokes throwin punches
i am not happy with the way the car corners at the moment! turn in yeah it's ok the front feels solid but the rear twist under harsh cornering! i had a look at r34's to why they'feel solid and it turns out the reinforced the rear with some sort of brace behind the rear seats! basically there's too my flex more my liking!
isnt there a dedicated thread for that?
yes, but theres nothing saying i can't post it in here.
well just come back from down the street, there was a heap of people waiting on the side of the road
just waiting to see some bikies. there was a heap of police aswel, think there was 3-4 bus loads of police with
riot gear lol, i swear they had more police assistance than the Queen when she was here haha
sway bars help with body roll! but you can get a hint with the rear that it flexes while turning at higher speeds under acceleration
Replace every bush in your suspension with nolathane or alloy bushes, bracing the chassis wont do much if your still have rubber flexing in the suspension.
Have you got cradle bush spacers? If you haven't then what you are feeling is the rear cradle bushes deforming. Get some urethane pineapples and it will improve the feeling 100%.
Ok so having a weird strange problems with my car. Had baffle plate in coz of defect and have just recently put back in my stock ecu with remap including gtr injectors which are still in the car.
My car will run on low revs going thru the gears but as soon as i put my foot down to get it a squirt shoots massive black smoke out and doesn't move literally looses all power until i back of and slowly increase.
HELP PLEASE. I've changed plugs helped for a little
P.S i can still rev the s##t out of it while in nutral with nothing
Done the usual clean/check of the AFM? Could cause a similar problem, obviously the remap supports the bigger injectors yes?
Also, maybe an IC pipe has come off, loosened or one of the silicon joiners might have a crack in it. Check them all, you'd be surprised. Me and Steve both had a similar problem, that was the cause
    • Due to series of unfortunate events the 32 is currently my daily. Fuel economy and jungle gym aside it has not been too bad to drive around. That was until the ol' Varex decided that ~15 years and ~8 of those years on E85 was enough. The butterfly valve separated from the motors' shaft and managed to wedge/weld its self in the closed position. the varex when rapped sounded like there wasn't any packing left in it either. New Vibrant 3" muffler was selected to go in. While it is a shame to lose the quiet mode, the new Vibrant muffler definitely gives a more mellow/rounded tone which sounds great. To me it also sounds louder than the varex was open... so there is that. sorry neighbours
    • Down shifting = Right gear, right RPM, right road speed! Try rev matching on the down shift
    • Why would you ever need to "hard change down" from 5th to 4th? Any time you're in 5th and need serious accel, you're looking to go down to 3rd or maybe even 2nd, anyway. Just treat your 30 year old gearbox with some respect.
    • Anyone else have a grinding issue changing from 5th to 4th gear. I have no issues 3rd to 4th and 4th to 5th. But the car seems to grind a little when I do 5th to 4th …    is this a common issue? Had it from the last owner. Bit annoying as I can’t hard shift down. Feels like I have to push a little to the left to get it smoother into gear.    thanks
    • I would, especially if the car has had a few start ups or short trips to move it around  But then I'm anal as fark about oil changes, as oil is cheap, and servicing is fun.....
