my house mate told me yseterday that he brakes are making noise....
just had a quick look, i think i can see the problem...
can u say metal on metal?
those are the deepest grooves i have seen on a disc, they are about 3 - 4 mm deep
yeah looks good Matty but don't know how comfy the Patrol boys would be having a 200 around..........lol, it won't matter whether I can keep up with them or run rings around them, the fact that it's a 200 will get me flamage.
EDIT: Not to mention that I'm still running the factory Dunlop Grandtreks (crapiest tyre ever designed for a 4WD). Need to put some M/T ATZ's on there but I'd be looking at almost 1/2 grand a corner :D
i dont think they'd mind. someone always brings a mate along with another make of 4wd, there tends to be floaters with pajeros, cruisers and the likes. even on the Patrol Club of SA outings they've had Jackaroos and Subaru 1800 wagons :(
Im keen to see how the new Kelly Safari Trex go
i want some custom slots like that in my rotors too. it has a great feature of screaming like a banshee all the time... i need that too
just get some RDA slotteds from Rianto (rs73)... he'll hook ya up for a good price :D
-D
just get some RDA slotteds from Rianto (rs73)... he'll hook ya up for a good price :(
-D
unsubstanicted clap trap i dont appreciate that post there is nothing wrong with RDA rotors its the pads and how you bed them in
dont take this the wrong way
haha cheers craig :D
I never said anything about RDA rotors except to buy them. I've ordered some myself... WTF kinda high horse are u on today? Don't appreciate what post?
-D
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
