WANTING a track day
anyone know the upcoming calander? cant seem to find anything re: mallala track days
need track time - my stagea is really really good atm & I need to try it flat out
arr damm, just brought the stock ones off Mitch last night. O well.
Can someone buy me this please http://page4.auctions.yahoo.co.jp/jp/auction/d92921865
nice only 52k
can i still have them? I'll try and sell these ones then :P
cheeky much? :down:
Someone better tell Nissan that one Stirls, so they can remove the NISSAN ID PLATE number for the 07- GTR that goes R35-000XXXX (XXXX being the build number of the car)..... :down:
I don't need to, they already know;
With sales due to start in Japan in December, Nissan is today also confirming the final name of the car. Previous generations of this car were known as the Skyline GT-R; the new name for this car is simply "Nissan GT-R" in all global markets. Supporting substantial early customer interest in the Nissan GT-R, the company is today making available for customers in Japan some initial details including basic specifications, colors and practical information on placing pre-orders. Prices in Japan for the Nissan GT-R will start from around 7.8 million yen.
Reference;
http://www.gtrnissan.com/item.en.au.html?i...&type=press
Yes Pete I was talking about an R35 Skyline GTR, and Yes Mr Donnon my wording was incorrect.
Edited by D_Stirls
WANTING a track day
Luke aka Skylineguy19 he is organising a closed track day hit him up with a PM
ROR indeed....talk about being 'rost in tlansration' :)
for those not doing anything today (and not goin to the race)
havin a bbq at mine to watch the race
bring drink, bring meat.........i supply bbq, plasma and fridge
starts from 12............giv me a holler if ya coming :)
good one sunshine......now you tell us.......I was on a ride not far from your place today :blink:
haha, well i did send a bulk message out during the week and didnt get any replies aside from the people that already knew i was organising it (oh and from andrew to brag he was going to be there for the 4 days)
how would one go about getting a flywheel off a block
use a rattle gun ?
shits on their tightly (which is good)
pic for reference (the bolts in the middle):
get a socket to fit the harmonic balancer at other end
get socket to fit those bolts
2 people, 2 breaker bars - one at the front end of the motor, one on the rear of motor
i assume you could just use a rattle gun with one person as it wont spin the whole thing, just the bolt your trying to undo.
Dont trust me on that tho.
Edited by Luke_ENR34
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
