The Sa Wasteland
Cubes
 Share
Evos are unbelievably fast when you see them in action. A mate has an Evo6, have cruised with him and done hills drives with him, unbelievable.
And the sound that thing makes at high RPM is phenomenal, never heard anything like it, it was.... like a bark more than anything.
Phenomenal cars, love em. If you see them driving flat out you will appreciate...
i have always had a soft spot for Evo's specially the TME ones
have seen them in action and as Ahmed said they are phenomenal machines on full song
Problem is they are worth much more than 33's so a trade up is not on the cards, not as long as we keep throuwing money into that sexy R33-shaped pit.
.................... go the money pits.
Beauty about Evos is the standard ECU, AFM, injectors, etc... can handle so much. This guy pulled up next to me at the lights and turned his boost up to 19 PSI and took off.
Right now I'm running 13 PSI and can't run any more without spending big dollars, injectors, turbs, ECU, bla bla bla all the usualy crap but that's a lot of dosh.
he can get in a standard evo 6 (apart from exhaust) and turn it right up. I'd be interested to see what it puts out on a dyno....
got a few mates with evo's and quite frankly i wasn't impressed! maybe all of the hype about them didn't meet my expectations, it was fast shit you not but to me a rwd is still more exciting! but i guess i don't like them but respect them for being fast!
I have driven a EVO VII GTA - Automatic ones, at my old work and they launch awesome and handle so good,
Get one Jarrad, and sell me your XD9's :(
^doubt it... i'm putting down almost 200 and he was miles ahead, 4 car lengths....
was this of a stand still launch, if so they of course he will be in front and given a long enough rd you would reel him in
steve's onto a point
evo's, rexes and the like are quick off the line, but are limited to top end gearing (considering their heritage is for fanging sideways on gravel at 140+kmh)
mid sized cars (skyline, supra etc) are relatively quick off the line, but still have a better top end than the smaller 4wd turbo cars
then ya big 8s are good for top speed, but not really for take off with extremely low gearing
Those things dont need to push out massive power to get a good start man...AWD launch FTMFW
 Share
    • Yes, it's similar length.
    • Is the CD009 similar length from bell to shifter?    car will just be for the street with the odd track day. It’s RB30det, and weighs about 1000kg
    • The r34 gearbox is like $3400/3700 landed from Japan sometime last year.   Contact jessestreeter.com for info and quotes. From memory the navara gearbox needs input shaft machined down as I looked into a while back and there's a thread somewhere here from 2018-2021 about it. Depends on what your doing with the car maybe worth the dollars to go cd009 or a 8hp50/70.
    • VCAM doesn't really increase peak power, it just widens the powerband. So if you were giving up power with adjustable cam gears to get better low-end response yes in theory it "increases power" but otherwise not really. Stroker kit might put you in a more efficient region of the compressor map which will get you more power but at say 7000 rpm I'm not sure that much will change. The original HKS GT2530, -5s, and GTX2860R gen 2 are all roughly the same kind of turbo. If you want 600 horsepower those are the turbos you need. So 500 whp. Just expect to spend some quality time trying to figure out intake/exhaust piping. The "twin turbo" pipe is an obvious place to start. Make sure the actuator preload and all of that fun boring stuff is set up correctly. Throw a VCAM step 2 at it if you want good response, 2.8L stroker too. If you're not actually wedded to 500 whp all the time you can barely get there with -7s or Nismo R3 turbos, you just have to run E85 or race gas and run them hard:
