selling roof rack isnt easy haha. mind you, just found out its universal gutter mounting. ebay sucks for trying to do anything atm, trying to upload a pic again and its not playing ball
lift kit rocks in monday w00t w00t
yeah ill be running a surge tank, hoping to keep the walbro 500hp fuel pump i got for the surge tank and then have the 1000hp external pump going to the fuel rail.......basically the pump ive found is equilvant to two bosch 440's.
# For high horsepower EFI applications making up to: 1600 HP - Naturally Aspirated
# 1100 HP - forced air induction
# Now with more flow and extended warranty
or
http://www.rocketindustries.com.au/search.php?brand=Fuelab
Yeah but more looking for something that i'll have no chance (well i guess nothing is impossible) of modifying in any way.
    • Hmm. I should have thought of the clutch bleeding issue. It should be #1 thought for "can't select gears". As to "sounds like the top".....have you actually gone out with the stethoscope and tried to pin it down any more than that? And, buy or borrow a timing light, and set the timing properly.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
