cara, upgrade your freakin brakes. even a dyno bitch and streeter needs competent brakes. spesh if youre putting down 800hp. id rather have the brakes and not need em than need em and not have em.
opinion stated.
rb stickers, dosnt anyone like sleepers these days :)
i prefer the dont need to brag about being able to whip your ass at the lights approach.
but then it might get 1 or 2 bogans to accept they cant beat you and not rev you at the lights
this is what Dan uses for a sleeper :)
clearly those pellets went straight through that door
having red stuff pads in a small car is not a good idea unless its just for the track tho... in my bro in laws pug 205 GTI u have to get the passenger to help stand on the brake pedal when the pads are cold ROR
huh.....I thought it was for her 34?!
Your bro must have other issues Carl (condensation in the fluid can have a similar effect sometimes).....Red Stuff has a very low coefficiency which makes them quite effective when cold, mine would throw you thru the windscreen 1st thing in the morning on the way to the shops.
EBC Pads
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
