huh.....I thought it was for her 34?!
Your bro must have other issues Carl (condensation in the fluid can have a similar effect sometimes).....Red Stuff has a very low coefficiency which makes them quite effective when cold, mine would throw you thru the windscreen 1st thing in the morning on the way to the shops.
EBC Pads
interesting to see that the effective temp vs braking force at the low end is pretty consitant through the lower end of the range.
looking at that chart, something must have gone wrong with the brake set up, as he used to have yellow stuff on the car, and it was much more streetable than it was with the red.
the brake booster has since been replaced on the pug, i have not had a chance to drive it since then, as its now a hill climb car that lives in a shed.
yeah that does seem somewhat strange Carl.....especially with his experiences with the Yellow Stuff.
Guys like Chad (Dstroy), Andrew (Blue32) and eventually Luke (ENR34), who regularly track their cars, could do alot worse by not at least trying the Yellow Stuff.
For track only, the Blue Stuff freaks me out a bit cause I'm guessing that not only would they squeal like a pig on heat but they would be very hungry on the rotors.......hence why the Yellow Stuff would be a good option......cheaper and quicker to replace pads than rotors.
can i give your car some finishing touches with a shotgun cara?
guaranteed 1st prize !
yeah no dramas carl.....just make sure the design looks half decent ok!
6 or 8 pot?
depends what i can find at the time......maybe just have to go with r33 gtr 4 pot....but considering the car isnt going to be drivin stupidly hard they should be all good for what im gonna be usign her for
they are for the 34 :)
i quite liked the sig!
tis a bit large tho. in consideration, sig scrapped...
BOLOGNESE :)
i see its back again :)
its been reported
a signature by definition isn't a movie its a picture that the community can quickly see who has posted, 1403.43 KB (1437109 bytes) is inappropriate
you may see this as harsh.... to bad
i see its back again :P
its been reported
Maybe you better report your mate Heslo, as his is a movie also.
his isnt 1.4mb
from memory its 600kb edit not even 478.36 KB (489841 bytes) thats why i have never complained about it
yeah Carl cables extreme unlike Sydney we only get 256k upload
lol, there are perhaps some things i can do....
not sure if u are aware, but there is a flaw in the monthly quota being reset, and u actually get unshaped the day before your account anniversary date... so there is the potential to wax about 18Gig on the last day at full speed if u have good torrents or use news groups.
im pretty sure that only works if u are shaped b4hand tho
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
